Michael99Vette
Second - you said it's an automatic, I'm betting it has the 2.73 rear gears. If you check the RPO sticker on the inside of the glove box door, you'll probably find GU2 which is the RPO (regular production option) code for the 2.73 rear end. For your reference, there were three different gearsets used in the C5.
2.73 was standard with the A4 automatic
3.15 was the optional performance gearset on the A4
3.42 was the standard and only available gearset with the manual MN6 transmission.
Lot's of folks have upgraded their gearsets to something higher, one of the most popular for the 2.73 is to go to the 3.42.
Another way you can verify this other than looking under the car and looking for a tag on the differential is to drive the car in 3rd gear at 70mph. Look at the tach, read the rpm's and divide by 1000. If you have the 2.73, you'll be turning 2730 rpms.
With a higher numerical set, you should have no problems getting rubber.
Thanks again.
I came from an 85 also,and I now have a 98 as well.So, we kinda have the same history brotha
There is a small hesitation when you punch it as it drops down in gears from a roll,so what you are experiencing may be normal and not a tune up issue.
I had 3:15 gears and went to 3:42's.It made the perfect compromise for me. Lot's of performance with little sacrifice at cruising speed and gas mileage. I love it!
In your scenario,coming from 2:73's,it will be a HUGE difference.It will feel like a completely different car for you.
As stated above, if you are careful and get a good , no issue used differential,you should be able to pick one up in our own "parts for sale" section for +/- $500.00. Labor to swap it should be around $400 or so.You may also be able to sell your existing diff for a couple hundred,if you find the right buyer (although they are not in super high demand)
So, taking this avenue you could be in it well under $1,000.00
OR, you could go new parts and labor for somewhere in the $1,700.00 ballpark figure
Best bang for the buck in your position.
Congrats on your new(er) Vette!!
Thanks for your "congrats". I love this car. It's so far advanced over that 85, it's unbelievable. Now... if I do buy a new ring and pinion gears, what size is my rear end (8.25, 8.5, 8.75, etc.)?
