Strange Vibration ::Please Help::
Old Jul 6, 2009 | 12:13 PM
EllisJuan350's Avatar
EllisJuan350
Default Strange Vibration ::Please Help::
Ok well about 3 months ago(i dont drive the car often) i noticed a wierd vibration in the floorboard of the car.
My 2000 is lowered on stock bolts but has never had an alignment, So i took off the front wheels and sure enough the inside of the tires were down to the wear bars but when i started rubbing my hand over it i noticed about half dollar size bubbles threw out the entire tire, well i thought for sure this was the problem so i bought new fronts...Still didnt fix it.
The wierd thing is when the wheel is turned to the right your REALLY feel it, when its straight its very slight, and when its turned to the left you dont feel it at all. And you dont feel it very much in the steering wheel either, just everywhere else.
A friend of mine said i should probobly go get an alignment and see if thats the issue.
I drive my car very carefully, i havent hit any potholes or anything else for that matter so i know i dont have a bent wheel.
Any help would be greatly appreciated.
Old Jul 6, 2009 | 12:24 PM
El original's Avatar
El original
Need more info., how many miles on it, did you finally get the wheel alignment and did shop stewards give you any heads up on potential problems. Many vibrations can occur from engine components eg. water pump, alternator etc. give us something to work with!
Old Jul 6, 2009 | 12:46 PM
georgec114's Avatar
georgec114
Also...At what speed(s) does this happen?
A 2000 is definitely past diff fluid change.
Old Jul 7, 2009 | 06:27 PM
EllisJuan350
The car has 60k on it, i never got an alignment done.
It does it at any speed also.
I feel it has something to do with something thats rotating, because the faster i go, the faster the vibration seems to go.
Old Jul 7, 2009 | 07:25 PM
dobewillie's Avatar
dobewillie
good luck getting it corrected
Old Jul 7, 2009 | 07:58 PM
EllisJuan350
bump, any ideas?
Old Jul 7, 2009 | 11:08 PM
NEVERL8C5's Avatar
NEVERL8C5
Does it feel like it is cycling? Last for a few seconds leave and then repeat? This could be a hub bearing.Most times if you feel it in the seat of your pants it is coming from the rear of the car. Also check the axle nuts for proper torque sometimes they come loose.Also check that harmonic balancer they tend to get a bad wobble in them. Just a few sugestions
I have had all of the above happen.I do drive my car everyday so I get my share of repairs.
Old Jul 8, 2009 | 12:02 AM
jrose7004's Avatar
jrose7004
First I'd get an alignment.
Old Jul 8, 2009 | 12:19 AM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Take care of the simplest correction and move on to the more challenging, after 60,000 on a lowered car an alignment is in order anyway.
Old Jul 8, 2009 | 02:06 PM
EllisJuan350
Well thanks for the suggestions guys.
Old Jul 12, 2009 | 12:27 PM
NSTG8R's Avatar
NSTG8R
interested to know the outcome.
i've got the same thing happened but i'm at 160k lol.
personally I was thinking front wheel bearing - but was going to try an alignment first - seems it happened after a trip to hell in Toronto (car fell into a pothole).
have to wait til i get back down south to a quality shop. lol.
good luck. cheers.
Old Jul 12, 2009 | 01:13 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Does it feel like a buzz that's consistent and not cycling? If it's a constant buzz and goes away when you turn the wheel left, I'd bet dollars it's your front right wheel bearing going out. Had the exact same symptoms when turning the wheel on my Trans Am when I first got it, turn to the right buzz/vibe got bad, turn to the left it went away.
Old Jul 13, 2009 | 12:48 PM
EllisJuan350
Its a cycling vibration thats seeming to get worse, Im gunna take the wheel off today if i have time to see what the deal is.
Old Jul 13, 2009 | 03:41 PM
xxSPEEDDEMONxx's Avatar
xxSPEEDDEMONxx
I know what it is!!! I just expierienced this exact problem. I would get a vibration when veering right and nothing when going staright or left. It is a hub bearing. The hard part is figuring out which one. I ended up replacing them all because I got a good deal. Problem corrected and now she is smooth as ice. Good Luck
Old Jul 13, 2009 | 03:46 PM
lil vette's Avatar
lil vette
Is it a buzzing sound, when you turn wheel to right.
You could have a vibrator stuck between seat & console.
Turning left will turn it off.
Old Jul 13, 2009 | 04:49 PM
EllisJuan350
^^^You caught me
Im just surprised my wheel/hub bearings would go out and my car only has 60k on it, kinda dissapointing if this does end up being the problem.
To Strange Vibration ::Please Help::
