Tpms & fob programing help
Old Jul 7, 2009 | 11:05 AM
GEO 8's Avatar
GEO 8
Default Tpms & fob programing help
I just bought all the necessary parts to convert my 2000 system to a 2001 style
Can anyone send me a .pdf or some type of instructions on how to program the tire sensors and fobs
I thought I saw one out there, but cant find it now
geo
Old Jul 7, 2009 | 11:45 AM
TheBriton's Avatar
TheBriton
Geo,
Here you are. The search feature is our friend.
1) Turn ignition on
2) Press "Reset" button in order to clear any IPC display warning messages
3) Press and release the "Options" button on the DIC to scroll through the display options until the IPC display is blank
4) Press and hold the DIC "Reset" button for 3 seconds
5) Press the "Options" button again until TIRE TRAINING message appears
6) Press "Reset" button until the IPC "Learn L Front Tire" message appears in order to begin the programming
7) Install the J41760 Tire Pressure Monitor (TPM) System Programming Tool (large magnet will do) over the left front valve stem
8) The horn will sound, indicating the left front TPM sensor is programmed (if this takes more than 15 seconds, pull magnet back and try again, it will give you three tries. Then you must start over)
9) When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages: -Learn R Front Tire -Learn R Rear Tire -Learn L Rear Tire Programming can be canceled by turning ignition off, waiting 2 minutes with no sensors being learned, finishing all 4 wheels or through the DIC. If the programming is canceled with less than 4 sensors learned, it will only accept the codes programmed up to that point.
Old Jul 7, 2009 | 12:02 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Fob and TPMS training is in the owner's manual. If you did not get an owners manual - here's a .PDF version for the 2000....
http://www.corvetteactioncenter.com/...00corvette.pdf
Old Jul 7, 2009 | 12:20 PM
GEO 8's Avatar
GEO 8
THANKS..............you are da man!
Old Jul 7, 2009 | 12:25 PM
GEO 8's Avatar
GEO 8
does it matter that I am programing a 2001 receiver?
To Tpms & fob programing help
