I cleared my codes without getting them recorded, my bad. I failed the inspection with cat, O2 evap. It took about 3 days for it show a new code PO410HC Any ideas on which O2 sensors or what I nned to fix to get this code fixed? I would appreciate any help.
P0410 is secondary air injection code.
A little more info on year of car, miles and model would be helpful
My vette is a 2003 with about 78,000 miles. The check engine light has been coming on now and then for a long time. On more than off. It seemed at times the light would go off after putting in Shell gas. But lately the light has stayed on.
My 98 kept throwing this code when I ran 87 octane.As soon as I upgraded to a minimum of 89 light went out and code went to the h or history.C at the end is current.The root of the problem is usually the air check valves behind the intake.Good luck.
I had the same code keep poping up -- Replaced the downline 02 sensor on the left side -- ($166.00) from Fred Bean -- Also replaced the relay for the air injection pump -- Problem fixed -- Code was comming up every time I started the car -- After it warmed up & I cleared it, it would stay off untill the next warmup
I have been running premium gas for over a year. It is a little ironic that my gas cap did fail the inspection test the first time, then he tested it again and it passed.
