Column Lock Rant
Old Jul 11, 2009 | 05:00 PM
Eric the Ricer's Avatar
Eric the Ricer
From: Beyonce > Taylor Swift - Welcome to the good life!
St. Jude Donor '07
Default Column Lock Rant
Currently sitting in a parking lot, waiting for individuals to leave so the tow truck can fit. Luckily my wheels are locked straight ahead. Just dropped $80 on groceries that are going to waste in the heat. Previous owner assured me the recall had been taken care of.
PISSED
Old Jul 11, 2009 | 05:16 PM
WildTurkey's Avatar
WildTurkey
Sorry about this man - sucks bad!
Old Jul 11, 2009 | 05:40 PM
HawnHog's Avatar
HawnHog
Previous owner may not have been lying. The recall(s) do not necessarily work. Get a CLB.
Good luck.
DsC5's Avatar
DsC5
Try turning the car off, on, off, turn wheel, taking key out, locking the doors with the fob, unlock, start over. A few times when my column locked it freed up that way.
Old Jul 11, 2009 | 05:42 PM
Trpblk04's Avatar
Trpblk04
Recall did not always work; CLB $50.
Old Jul 11, 2009 | 06:23 PM
jodfit's Avatar
jodfit
St. Jude Donor '07
FYI: GM only backs the recall repair for one year, if it malfunctions after that, you are on your own.
Old Jul 11, 2009 | 07:45 PM
Eric the Ricer
St. Jude Donor '07
so column lock bypass will fix my woes? they are talking a few hundred dollars here...
Old Jul 11, 2009 | 08:59 PM
HawnHog's Avatar
HawnHog
I believe if it's already locked - NO! You'll have to get it unlocked first. Try talking to the guys at Corvettes of Houston. (Mike I believe...) They sell the CLB for about $50 and have all the free info you'll need.
Old Jul 11, 2009 | 10:47 PM
Try the vendor HawnHog recommended or Thunder Racing. Both offer the CLB at a good price.
Old Jul 12, 2009 | 12:12 AM
dodriven's Avatar
dodriven
You've had the car a couple weeks now, right?
My FRC had the recall performed and the column lock worked just as it was supposed to.
But still... I ordered the CLB 5 minutes after I pulled the car into my garage for the first time. It's cheap insurance, I see no reason not to do it.
Old Jul 12, 2009 | 12:21 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
PISSED
More proof that the GM recalls do not work
Old Jul 12, 2009 | 05:11 PM
Eric the Ricer
St. Jude Donor '07
Thanks guys. I'm gonna talk to them tomorrow and see how bad they're gonna screw me. Hopefully I'll be able to get it taken care of cheap. First thing I'm doing is buying that CLB and putting it in once it's home. I need new tires bad! I hope this doesn't kick my azz.
Old Jul 12, 2009 | 05:18 PM
dodriven's Avatar
dodriven
Good luck.
I'm guessing you already tried it, but jamming the steering wheel a couple of times side to side can knock it loose sometimes. If you can get it loose try, put the key in turn it to 'On' and hopefully you will hear the lock motor release. Worked on a friends car.
Old Jul 12, 2009 | 05:19 PM
Trpblk04's Avatar
Trpblk04
Yes once you unlock then you can install; I purchased mine from Corvette's of Houston.
To Column Lock Rant
