Recommended Tire sizes
Old Jul 12, 2009 | 02:06 PM
jhiiidoc's Avatar
jhiiidoc
Default Recommended Tire sizes
I recently puchased new rims for my 02 Vette. However, I failed to note the width of the new rims, which are 1" wider both front and rear. So now I need new tires as my tires will not swap onto the new rims.
I can't seem to find a tool to help me select the right sizes, so I am turning to the gurus here in the forum.
What are the possible tire sizes for the following rims?:
17 x 9.5"
18 x 10.5"
Old Jul 12, 2009 | 02:26 PM
Leonie's Avatar
Leonie
I heard rumors, that there once was a car called the C5 Z06, having the exact rim sizes you have bought, but please, do not tell anyone!
So 265/40-17 and 295/35-18 would be the optimum, but I know some people having the C5Z rims on standard C5´s with the standard C5 tire dimensions (245/45-17 and 275/40-18), without having any issues..
Best, Bernd
Edit: the standard sizes on the wider rims were not runflats!!
Old Jul 12, 2009 | 02:29 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
17 x 9.5"
18 x 10.5"
Those are the stock Z06 widths.
I have the GM Z06 wheels and am running 275/40x17 front and 295/35x18 rear. I believe the stock front size was 265/40x17 for the 9.5" wheel.
Old Jul 12, 2009 | 02:49 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have 9.5 wheels on the front with 245.45.17 and the rear are 275.40.18 10.5 wide I believe.
Old Jul 19, 2009 | 07:27 PM
jhiiidoc's Avatar
jhiiidoc
Okay...
I'll give it a try...we'll see if they'll fit.
Hope you all are correct. Otherwise it's $650 foor a new set of tires.
Old Jul 19, 2009 | 09:19 PM
Quickshift_C5's Avatar
Quickshift_C5
I'd recommend getting the correct tires, don't stretch the tires onto the wheels.
Old Jul 19, 2009 | 09:24 PM
Jims2001's Avatar
Jims2001
Just where did you find your rims? Are 6they chrome?
Old Jul 19, 2009 | 11:06 PM
Rapid Fred's Avatar
Rapid Fred
to a point...
I had this problem when I bought Argent -- the prior owner had the wide rims and the stock-sized tires. I thought the fronts looked terrible and the backs barely OK. I was also concerned about safety.
Long story short, I learned that 275's are OK on 10.5's, but 255's are the recommended minimum for 9.5's. I bought Kumho ASX all-seasons in the 275/255 sizes (they did not have Z06 sizes) and sold the nearly new Toyos that were originally on there. The 255's look pretty good and the 275's were a tiny bit wider than the Toyos so they look OK too.
So, you can safely keep the rear tires but the fronts are "stretching it" so to speak...
To Recommended Tire sizes
