I just wanted to give a product review on this stuff. If you've got lots of little pecks, this stuff is fantastic. You dab the paint on, smear it with your thumb, give it a few minutes and then wash off the excess with their remover. It gets ALL the excess and leaves all the pecks filled in and it really does work. I bought it and tried it on my wife's Lexus (I damn sure wasn't going to try that out on my baby until I knew it worked! ).
Just one caveat, it will LOOK very good. It will fill in all the pecks. But it is a TOUCH UP SYSTEM, not a new paint job. You can still run your hand over the paint and feel the pecks. You just won't see them. I think a little edge sanding and a second coat might fix that too, but I haven't tried it yet.
To the OP, do you have any before and after pictures?
No, I didn't take any. Sorry. But the gist is that on my wife's SC430 with its big blunt front end, there were hundreds of little white pecks. Now, you can't see any at all. You can FEEL them, but you can't see them and all the excess paint around the chip is removed with their cleaner.
As for Millenium Yellow, you have to send them your make/model/year and paint code so I assume that they send you the exact color for your car. As mine is black, it's a bit difficult to tell just how good the color match would be on something like Millenium Yellow. Sorry.
On edit - I went outside to take some pictures of it now, but the light isn't good enough. It just shows a black car. If you think it'll help, I'll try tomorrow before it gets dark and see if I can get you some better ones.
Well, the forum guidelines say you can't do so in a manner that winds up being an advertisement for the company.. I think in this case his genuine review is pretty safe, he's just providing some information and his experience with it... I hope that's still okay or I'll have to head for a forum where discussion of FARTING is allowed.
Wow... I don't think $50 is to much if it works to mask road rash. If it even masks the rash, I'm good to go. Beats paying $700+ that I've been quoted to clean up the front end and hood.
I tried this on MY on my door. I had a scratch in the door and on the very edge of the door. Its an improvement; but it's easily seen if you are looking at the car carefully.
I'm sure it is. Like I said at the start, it's a touchup, not a new paint job. Just as if you carefully used touchup paint and filled in the spot, you'd still see a chip that had been filled in.
The advantage is that it ONLY puts paint where the chip is and that you can apply to a very large area without getting excess paint on the surrounding paint. I don't for a minute want to give anyone the impression that once you've put it on, the chips are invisible because that's not the case. They're just touched up.
