Trick to the memory settings?
Old Jul 15, 2009 | 11:57 AM
bluerose's Avatar
bluerose
Default Trick to the memory settings?
So I turned on the option to move the seat back automatically so I could get in and out easier with my back. My preferred settings are on Memory 1.
Everything was doing fine until the other day then it suddenly started use Memory 2 and I have to press memory 1 every time I get in.
Anyone know what happened and how to reset it to use Memory 1? Can I just disable then re-enable the option for moving the seat back?
Old Jul 15, 2009 | 12:08 PM
YNOT2K's Avatar
YNOT2K
is it possible that you changed key fobs the other day?
each fob has it's own user setting and if you're using the fob for user 2 then it moves to the user 2 presets.
i have 2 fobs - the one i use all the time (user 1) and the spare (user 2).
take it easy,
jeff
Old Jul 15, 2009 | 12:11 PM
bluerose's Avatar
bluerose
take it easy,
jeff
Ahh....We added a new fob because I only had 1 key and fob when I bought it so I took the new one.....
I'll switch fobs and see if that does it. Thanks!
Old Jul 15, 2009 | 05:55 PM
Keep in mind too that unless you lock the car with the fob, the memory settings will not work unless you press the memory button.
To Trick to the memory settings?
