Michaline PS2 question
Old Jul 17, 2009 | 07:52 AM
zx14's Avatar
zx14
Default Michaline PS2 question
On there site I am looking at 295/35ZR18 tires. there are 2 listed on the drop down. when you open the specs page you get:
#1 is M# 43008 org. eq. for Mercedes Benz and it measures 11.85" wide on a 10.5" wide wheel.
#2 is M# 05271 and says it is org. eq. for Porsch and it is 11.9" wide on a 10.5" wide wheel.
What gives?
Old Jul 17, 2009 | 09:02 AM
BillY2KFRC's Avatar
BillY2KFRC
I'm not 100% sure, I'm thinking they might use slightly different rubber compounds depending on the OEM application it was designed for. I went with the Porsche one and am very happy and found the front/rear balance to be perfect.
Old Jul 17, 2009 | 11:07 AM
dodriven's Avatar
dodriven
I am running the PS2 in the same size, I wasn't even asked when I ordered mine. I really doubt the tires are any different, but like Y2K said, I would go with the Porsche option just in case.
Old Jul 17, 2009 | 11:25 AM
ttribe's Avatar
ttribe
might have something to do with load ratings. Heavier cars need higher load ratings, different sidewall strength, etc.
Old Jul 17, 2009 | 05:50 PM
zx14's Avatar
zx14
Nop, both have max load of 1709#
Old Jul 17, 2009 | 07:14 PM
japc5's Avatar
japc5
Drop luke luke@tirerack.com an email his knows this stuff inside out and will give you straight answer.
To Michaline PS2 question
