A4 burn out
Old Jul 19, 2009 | 12:59 PM
casey007's Avatar
casey007
Default A4 burn out
Hi guys
I have a newbie question on a standing start burn out with an automatic. Do most of you accomplish a burn out without foot on brake and raising the RPM? I can spin the tires and leave a small black mark, was hoping for more. The car has a 3.42 rear end, cold air and cat backs and predator tune.
Old Jul 19, 2009 | 01:02 PM
Trpblk04's Avatar
Trpblk04
Have a line lock installed very cheap and a good way to do a burnout.
P.S. You should have purchased a M6...
Old Jul 19, 2009 | 01:13 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Probably the best solution around, a "line lock", if you're pushing an A4.
Old Jul 19, 2009 | 01:43 PM
65convt's Avatar
65convt
Thats odd. A small Black mark. Are you just heating them up in one spot? Or are you actually tying to do a burnout?
My wifes 98 convt. A4 will fry the tires for about 60ft or more until I let off the throttle.
Old Jul 19, 2009 | 02:19 PM
corvette8189's Avatar
corvette8189
foot on the brake and put the pedal to the floor and hold the brakes until you want to go
Old Jul 19, 2009 | 02:21 PM
Trpblk04's Avatar
Trpblk04
Originally Posted by casey007
Hi guys
The other absolute modification you could do, install a 3200-3500 stall convertor. A must do for the A4...
Old Jul 19, 2009 | 03:23 PM
lil vette's Avatar
lil vette
Don't do this.....will cause premature trans failure, in time.
Old Jul 19, 2009 | 05:54 PM
VinnyT's Avatar
VinnyT
Hmmm, odd.
I have an A4, with a 3:15 rear. Now I had a tune done from ECS. On a hot day, all I have to do is put it in D3, take the traction control off and mash the throttle. It'll spin until I let off. This is with runflats and on a 90 degree day.
Old Jul 19, 2009 | 06:13 PM
209TIME!!!'s Avatar
209TIME!!!
I sure would like to see that ....video or it's not true
Old Jul 19, 2009 | 07:53 PM
Trpblk04's Avatar
Trpblk04
Actually, it will give you a tighter shift and should last longer so the real builders tell me. Not sure who you spoke to? I raced several fbodies with built th350 from Rosslers in will outlast factory hands down.
Old Jul 19, 2009 | 09:56 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
how does one install one of these and how much do they cost?
Old Jul 19, 2009 | 10:04 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
You probably have sticky tires...
Old Jul 19, 2009 | 10:27 PM
ljthe2nd's Avatar
ljthe2nd
http://www.fastbirdperf.com/C5/C5LL.htm
This should help.
Old Jul 20, 2009 | 01:17 AM
itzza427's Avatar
itzza427
No one asked,,so I will. Did you turn off traction control??
Old Jul 20, 2009 | 01:32 AM
Smooth9883's Avatar
Smooth9883
I feel your frustration. I can't even light up the tires a bit. I think my 99 buick regal had more jump off the line.
I live just outside of Denver and I'd hate to say it but a corvette just doesn't have enough power. The a4 makes it even worse.
If a Subaru or vw with a turbo pulls up next to me I won't even try to race them. I don't want to be embarresed.
From what I've learned the only way to do a proper burnout is to get more power. For me it is going to be installing a supercharger and upgrading the transmission.
Old Jul 20, 2009 | 01:49 AM
TooMch's Avatar
TooMch
Definitely a line lock. And Shawn at fastbird has an excellent product and is a stand up guy. I have one of his line locks on my 01 A4. I have 3.42 gears and a 2800 vigilante stall. My recommendation, though if you are getting an aftermarket stall and want the best street driving manners would be to get a Yank. The vigilante is a little loose on the street.
Old Jul 20, 2009 | 02:08 AM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Alright, forgive my ignorance, but what does a line lock do, exactly? Just lock up the front brakes so the rear wheels can spin freely? Is that it?
(never mind, google is my friend). Looks like a nice mod to have if you do a lot of burnouts.
To A4 burn out
Old Jul 20, 2009 | 08:11 AM
silversport's Avatar
silversport
This cannot be said enough...I remember my first time (with this on...)...embarrassing...
Bill
Old Jul 20, 2009 | 08:54 AM
VinnyT's Avatar
VinnyT
Hmmm, that doesn't sound right. What rear end do you have? 2.73? 3.15? Also, when was the last tune up done?
You may want to clean the MAF sensor too.
Old Jul 20, 2009 | 12:13 PM
Shirl's Avatar
Shirl
Something's wrong here.. doesn't make sense..
