Newbie with a ?
Old Jul 20, 2009 | 09:23 PM
Nattex's Avatar
Nattex
5th Gear
Default Newbie with a ?
Hi All, Just took delivery of my first Vette. It's a 2000 Red Convertible, automatic with 47,000 miles. I have put around 200 miles on it, and I'm already hooked. What a great machine! I have already run across some issues that need to be taken care of, but they all seem to be typical problems, ie rocking seat, power antenna, and flasher bypass. Now for the first of what I am sure is going to be many questions. What is the module under the driver side cover in the rear? I was just cleaning up the trunk area and found this. Both plugs are unplugged. Should they be plugged in? Thanks in advance. I look forward to learning everything I can about my new Sports Car from everyone here.
Old Jul 20, 2009 | 09:47 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Originally Posted by Nattex
Hi All, Just took delivery of my first Vette. It's a 2000 Red Convertible, automatic with 47,000 miles. I have put around 200 miles on it, and I'm already hooked. What a great machine! I have already run across some issues that need to be taken care of, but they all seem to be typical problems, ie rocking seat, power antenna, and flasher bypass. Now for the first of what I am sure is going to be many questions. What is the module under the driver side cover in the rear? I was just cleaning up the trunk area and found this. Both plugs are unplugged. Should they be plugged in? Thanks in advance. I look forward to learning everything I can about my new baby from everyone here.
Might be a CD disc changer. It was an option.
Oh.......and don't call your Vette a "baby".
It's a Sports Car.
P.S.
Welcome to the madness.
Old Jul 20, 2009 | 09:53 PM
Nattex's Avatar
Nattex
5th Gear
Sorry for the slip up. Its not a cd changer it has one and it is in the middle compartment of the trunk. This is in the driver side compartment, and is behind a cover.
Old Jul 20, 2009 | 10:29 PM
BanditDude's Avatar
BanditDude
It is the control module for F45 adjustable shocks. If it's handling OK and not throwing codes, it means that this option was probably removed from the computer when the previous owner installed standard shocks. Do NOT plug it in, as it will automatically re-install into the car's systems and, potentially, cause you problems and cost $$ to remove again.
Old Jul 20, 2009 | 11:09 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Absolutely amazing the knowledge on this forum.
Old Jul 21, 2009 | 12:43 AM
BAMvette's Avatar
BAMvette
St. Jude Donor '17
Oh Yeah.....
There be WIZARDS here....
Not me, tho....:o
Old Jul 21, 2009 | 01:13 PM
bucwheat's Avatar
bucwheat
Just ask,someone here will know.
Old Jul 21, 2009 | 01:19 PM
RedRacer20's Avatar
RedRacer20
OK, why would you remove the stock shock and use another setup?
Old Jul 21, 2009 | 01:26 PM
FormerBiker's Avatar
FormerBiker
Ummm cost? $1500 vs $300.
Old Jul 21, 2009 | 01:29 PM
RedRacer20's Avatar
RedRacer20
I guess the real question is....Are the $300 set better?
Old Jul 21, 2009 | 01:32 PM
Cod's Avatar
Cod
Bazinga!
St. Jude Donor '09
Welcome aboard, you're at the right place for asking questions.....although we may need pictures sometimes
Old Jul 21, 2009 | 01:37 PM
FormerBiker
Bilsteins are great shocks and the ride is fantastic.
The OEM ones with active handling have sensors and valves that adjust the stiffness of the shock when it feels movement on the roll axis. That is why they are expensive.
Old Jul 21, 2009 | 01:40 PM
Congrats on your car and welcome to the forum. Hope you get many miles of pleasure out of the Vette.
Old Jul 21, 2009 | 03:26 PM
STIRitUP's Avatar
STIRitUP
Welcome to the forum and congrats on the car!!! Post some pics
To Newbie with a ?
