How do you shift your M6/M12?
In a car with low hp, this was quite easy. Driving an F350 SuperDuty is easy too. You can hardly feel the shift.
In the vette, it's different. The clutch grabs pretty hard and you can really feel the shift. If I try, I can ease off the clutch gradually, hold the accelerater some, and the shift-shock is minimal. Though I feel as though I'm riding the clutch through the gears.
I'm just wondering if others are shifting with minimal to no shock, or not caring at all about this practice.
Option 2. Do not ever let anyone ride in your car.
Option 3. Sell the stick car and buy an automatic car.
I can't wait till someone starts a thread on how to open the door!
Don't worry about it. Usually I drive the hardest when I have somebody in the car in attempt to impress them anyway. Yeah, I said that. I wouldn't let off the gas or ease up on the clutch unless the passenger gets scared. It has happened..
As a result I tend to pay more attention to finding the right gear than worrying about how hard or soft the clutch engagement is. If a person can not deal with a little g-force, they are obviously riding in the the wrong vehicle.
With that said, I have learned that when shifting from the left or right side of the shift pattern to the center (usually 2nd to 3rd or 5th to 4th), using to your hand to push or pull the lever only, will allow the self centering mechanism to move into the proper gear.
Of course the same method of pulling or pushing only should be used when shifting between 3rd & 4th in the center position.
Applying any lateral (side) force in these cases runs the risk of moving into a gear that you may not want to get into. This could cause minor embarrassment from engine bog (2nd to 5th :bb) or engine damage from over rev (5th to 2nd, etc.
).I apply deliberate lateral force when shifting between gears which are located on the same side of the shift pattern (1st & 2nd, 5th & 6th) to over ride the self centering mechanism.
Finally, there is an electronic solenoid which activates at speeds, I believe, above 2mph which disables the ability to move into reverse.
I hope this insight may help prevent someone from making the same mistake that has cost $$$ for many others (although for some, it was just a good reason to rebuild the engine and double the HP!)
