service column lock
Old Jul 21, 2009 | 05:26 PM
mark spallina's Avatar
mark spallina
1st Gear
Default service column lock
i have a 98 c5 that is manual, had the column lock show up 3 weeks ago, had it towed to dealer, they charged me $398 to bypass this by putting smaller lock plate and switch. now it did the same thing this weekend, i had it towed in again. they said now they are going to install the CLB kit. i have a case # with GM but not getting anywhere with them. if it is a recall way as a consumer am i having to pay for it.
Old Jul 21, 2009 | 06:32 PM
jrose7004's Avatar
jrose7004
Do a search Mark and you can read about it until early next week!
Old Jul 21, 2009 | 06:48 PM
HawnHog's Avatar
HawnHog
As Jrose says you can read up on this till you are blue in the face. Bottom line, GM said that as of Feb 29th 2007 they will no longer be responsible for any column lock issues. I took it all the way to the top and was told: 1) if it was "fixed" the issue should not reapear (HA!) & 2) if it does reapear (huh?) take it to the dealer that did the original fix (and hope THEY) will honor their work (HA! again).
Old Jul 21, 2009 | 06:51 PM
dougbfresh's Avatar
dougbfresh
WOW, we haven't had one of these posts for ALMOST A WEEK.
Old Jul 21, 2009 | 07:24 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
Mark,
If your dealership did the initial "fix" 3 weeks ago, they should stand behind their work and replace the "K harness", which is GM's version of the Column Lock Bypass (CLB). The K harness is notorious for failure. Have the dealership unlock the column and replace the K harness again. Then as soon as possible order a CLB from Corvettes of Houston, Mid-America, or any of the Corvette aftermarket dealers. Take the K harness out, install the CLB and that should solve your problem. I say "should" because some `98's don't respond to the CLB.
You might PM member 8vette7 and ask his opinion on this. He has done a lot of research on this issue.
Good luck
Old Jul 21, 2009 | 08:03 PM
Trpblk04's Avatar
Trpblk04
I saw a post Saturday I believe...
Old Jul 22, 2009 | 09:29 AM
SSWEET's Avatar
SSWEET
You'll be back to the dealer again with their "fix". Purchase a CLB from one of the sources and embark on a DIY fix that will work......
Old Jul 22, 2009 | 09:44 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
now that sucks, the CLB would have fixed it for 49.00. they scammed you hard.
To service column lock
