battery causing demons?
Old Jul 22, 2009 | 04:47 PM
Lancejoker's Avatar
Lancejoker
Default battery causing demons?
Can a weak battery cause random codes and little demons of that nature?
Old Jul 22, 2009 | 04:48 PM
Marcs c5's Avatar
Marcs c5
Yes, by all means.
Old Jul 22, 2009 | 05:57 PM
Mr. Jean's Avatar
Mr. Jean
Yup Keep it charged up, for less problems.
Old Jul 22, 2009 | 06:07 PM
It certainly can. Might want to get the battery tested and see if it is going bad.
Old Jul 22, 2009 | 06:42 PM
Lancejoker's Avatar
Lancejoker
I already ordered a new one in preparation for an audio upgrade. I was just curious. Thanks for the info guys.
Old Jul 22, 2009 | 06:52 PM
Mr. Jean's Avatar
Mr. Jean
When adding extra audio power stuff, it's real important to keep it charged up. Get yourself a good charger to keep on it, when not driving it daily. Well worth the investment.
Old Jul 22, 2009 | 07:08 PM
dobewillie's Avatar
dobewillie
a weak battery can give yiu fits
Old Jul 22, 2009 | 07:09 PM
Lancejoker's Avatar
Lancejoker
It actually is a daily driver. Thanks for th heads up.
Old Jul 22, 2009 | 07:39 PM
Cybermind's Avatar
Cybermind
Absolutely! I began getting the "service traction control/ABS" message when my battery starting getting weak. I replaced it about a month ago and never got the message again.
Old Jul 22, 2009 | 07:47 PM
LoneStarFRC's Avatar
LoneStarFRC
Do NOT be surprised if your little message comes back sooner or later. A good fresh battery is always a good thing, but many time the ABS issue is unrelated to a battery with demons.
Old Jul 22, 2009 | 08:53 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Yes it can. It caused me problems and a new Optima fixed them all.
Old Jul 22, 2009 | 09:30 PM
Lancejoker's Avatar
Lancejoker
Thanks again guys. Exactly what I was expecting/hoping to hear.
Old Jul 22, 2009 | 09:46 PM
hill536's Avatar
hill536
I had two Red Top 75/25 Optimas in the car in the past three months and the ABS codes were frequent. For the most part the ABS 1214 code did not appear when the switch was turned on and allowed to cycle thru its warnings prior to starting. The Red Top voltage would be in the 10's and the service manual says 10.6 v is critical to the ABS module.
After Auto Zone called Optima they told us that the D75/25 yellow top was their recomendation for the Corvette. I have not had a light since the changeover and got the battery cheaper because of a rebate.
Startup voltage is generally 12.2 vdc.
Bill Curlee has a GREAT sticky on the tech forum and his advice should be followed if you do have a problem.
To battery causing demons?
