when I changed out the battery on my 00 coupe, I took it out, drove down to AutoZone, purchased new.. drove back home and put it in. Must have been 40-50 minutes of it not being there. I had zero issues.
Buy it at a place like autozone, etc.. and have them change it for you. they have a power supply with 12 volts that plugs in the lighter to save that data. Also you won't have to deal with bringing the core back.
I had to resync my remotes (Hold down both lock and unlock untill the horn chirps) after about 5 hours disconnect. I had it out for an hour and didn't have to do anything. You are supposed to go thru the idle reset procedure but if you don't it will recalibrate in 100 miles or so.
BIGHANK
