I bought a set of HID 6000k from JW Motoring and am really impressed. What is the general feelings on the HID Fog lights?
How hard are they to install? and photos would be helpful. I have a set of Z06 screens in place. Will they defuse the light too much?
Did mine from up on top with no problem. Raise headlight, disconnect battery (you do not want the headlights timing out and retracting on your arm ) and reach down in.
The most challenging part is deciding where to mount the ballast. If you decide to go HID headlights at a later date, you'll need a place for a second ballast.
For foglights, I usually mount the ballast to the inside of the corrisponding frame rail using 3M mounting tape
From: "This is not a psychotic episode, but a cleansing moment of clarity."
I mounted the ballast for the fogs with the same bolt that holds the fog lights in place. I just turned the ballasts sideways. Nice fit. Works well.
