Pop-up headlight problem
Old Jul 27, 2009 | 09:41 AM
cgilbert23's Avatar
cgilbert23
Default Pop-up headlight problem
Hey everybody!
I am a new vette owner...bought a 99 coupe Fri. night. After running it through a tank of gas this weekend, I noticed that when I turn off my headlights, the drivers side motor make a seriously loud noise! Its almost like the motor is hanging and continues to try and flip down the light after it has already closed. It is loud sitting inside the car, and even louder outside of the car.
I'm sure someone has had this problem and hopefully its an easy fix.
Old Jul 27, 2009 | 09:57 AM
Pchild's Avatar
Pchild
There have been a lot of threads about the headlights, you'll have to search and see which one fits your symptoms.
If it sounds like a machine gun, then you need to replace the plastic gear with a bronze one.
Search for the head light issue, I remember reading this when my headlights were acting up.
Old Jul 27, 2009 | 10:00 AM
cgilbert23's Avatar
cgilbert23
Yup, sounds like a machine gun! and as loud as a machine gun! I will start searching and see what I find Thanks!!
Old Jul 27, 2009 | 10:04 AM
I've got some files that describe how to repair the headlight gears - if interested, PM me your e-mail address and I'll send them to you.
Old Jul 27, 2009 | 10:09 AM
02MillenniumVette's Avatar
02MillenniumVette
This issue has been covered a lot.
Old Jul 27, 2009 | 11:02 AM
cgilbert23's Avatar
cgilbert23
I found the DYI thread, and have ordered the brass replacement.
Thanks Guys!
Old Jul 27, 2009 | 12:08 PM
ieatyllwcryns's Avatar
ieatyllwcryns
Brass is the way to go, much better than the stock teflon or whatever it is.
To Pop-up headlight problem
