key fob / entry memory problems
Old Jul 27, 2009 | 06:38 PM
seering's Avatar
seering
Default key fob / entry memory problems
OK i posted earlier thinking i might have a bad fob or 2.
But it seems that both fobs are fine as long as i dont turn the ignition off.
i turn the ignition off for more than about 5-6 seconds .. fob programming is gone. I have to reprogram them from them from the DIC.
Any chance there something like a always hot 12v wire to retain the memory settings after the car is turned off... next stop checking every fuse i can find
Old Jul 27, 2009 | 07:54 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
I think that is still a fob issue. there is a diy fix on here...seems there is a bad solder on the fob board. search it and try it.
Good luck with the fix.
Old Jul 28, 2009 | 08:23 AM
seering's Avatar
seering
Its possible .. also found its not a full reprogram.
after it quits working .. as long as i have the key in and on in some way ..
I can just resync.
Gonna borrow a friends fob thats working see if that one works as well.
Just found it odd that it happened to 2 fobs at once.
Going to retouch any solder points i can find on the fob .. and ive already hardwired the battery connections to the PCB so its not loosing those contact points.
gotta love lady luck... shes apparently looking to teach me a lesson recently
Old Jul 30, 2009 | 01:35 PM
seering's Avatar
seering
Fixed ...
As much as it really seemed to be related to something internal.
Pulling the fobs apart and retouching the solder points that causes problems... Amazingly .. fixed both the sync problems and the passive entry.
Thanks again all
Old Jul 30, 2009 | 02:22 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
glad you got it fixed
To key fob / entry memory problems
