wet throttle foot !
Old Jul 27, 2009 | 08:47 PM
D&A'sDad's Avatar
D&A'sDad
Default wet throttle foot !
I just finished 2470 miles in 48 hours through some desert heat up to 105!!!
I began feeling little drops of moisture on my throttle foot, then every now and then a few drops out the ac vents
I searched and found Bill Curlee's 2005 ac drain post/thread.
He mentions 3 udders on the drivers side, my 04 coupe appears to only have two and they both seem dry and empty (I milked as directed).
He also mentions a drain tube under the battery. If this is the same tube and location on a 04 coupe?....Are there any special instructions or resets that I have to do when putting the battery back in?
thanks
Old Jul 28, 2009 | 02:26 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
thanks
Access to the tube is best done from underneath the car on the passenger side up on the fire wall.
Old Jul 28, 2009 | 07:54 AM
rebelheart's Avatar
rebelheart
The ones you"milked" are for the cowl drains,the one you need to unblock is on the firewall down low on the right side,this is the a/c drain.
Old Jul 28, 2009 | 09:47 AM
D&A'sDad's Avatar
D&A'sDad
thanks guys. ..I will give a shot when I get home this evening!
Old Jul 28, 2009 | 05:25 PM
tramminc's Avatar
tramminc
I cut that tit off the auters for free flow.
Old Jul 28, 2009 | 06:25 PM
D&A'sDad's Avatar
D&A'sDad
Well I have milked all the udders and all were clear
I had to remove the battery to milk the on the passenger side but it was dry and clear as well
To wet throttle foot !
