Center console heat shield?
Old Jul 29, 2009 | 07:14 AM
biglite351's Avatar
biglite351
Default Center console heat shield?
Hello all,
I have taken apart the center console area and some of the dash in order to replace my shift boot and remove the HVAC module to get the dim display fixed. While it was off I was thinking about putting something under the armrest/console are to try to keep it cooler in there. I do not think that the heat would cause too many problems with whatever I put in there, but as I drive from Pittsburgh to DC from time to time… after 4 hours it is rather warm.
I do not want to buy a full insulation kit as I do not want to take out all of the rug and seats and all. I figured that while some of the parts are off, I would just do that section.
Does anyone have any ideas of what I can put in there? I thought simple things like tin-foil might work. I also thought insulation like you would use in a house, but that works by not being compressed and once I put the console back on it would compress it negating it’s usefulness.
I just thought someone might have solid ideas, better than just foil.
Thanks for the help,
Jim
Old Jul 29, 2009 | 10:16 AM
Florida Mike's Avatar
Florida Mike
Jim,
I am a building contractor and found a perfect thing at your local HD or Lowes. Go to the plumbing section and pick up either Oatey or Bernzomatic solder heat shield. Its a 9" x 14" piece of fireproof material used to dissipate heat while soldering plumbing lines.
They are $15 each so not real cheap but they worked perfect for me. Just peel back the carpet and they slide ride in. I used 6 on my 04. Two on each side and two below the console. You just have to be careful when reinstalling the console as the studs will be shorter due to the shields thickness but you can get the nuts on and indeed tighten them.
I have road tested mine over several four hour trips and it works pretty well. Probably not as great as the under car shield or the full insulation packs guys do but good enough for me as it costs around $100 and I had it done in less than an hour.
One tip is these shields come with brass grommets in them so you can hang them while soldering. Push these out to remove them as obviously the brass will transer heat which you do not want.
I think I took some pictures if you want to see them I can email them to you.
Mike
Old Jul 29, 2009 | 12:50 PM
jrose7004's Avatar
jrose7004
Those "abs of steel" help in that area.
Old Jul 29, 2009 | 01:00 PM
jrprich's Avatar
jrprich
I used two layers of Frost king on the sides of the tunnel and 3 layers on top. Helped a lot!
Old Jul 29, 2009 | 01:04 PM
tlc0706's Avatar
tlc0706
Interested as well...Florida Mikes idea looks good......remember several years ago folks were using a Frost King product that had 2 layers of foil sorta bubble pack form....people reported good results although not as much as the dedicated products....cheaper though....GL
Old Jul 29, 2009 | 05:08 PM
Florida Mike
TLC,
Send me a PM or an email and I will forward you the pictures I took. I don't have picture posting rights or I would have just posted them.
Mike
Old Jul 29, 2009 | 07:22 PM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
Some great ideas, mine tends to cook pretty good, I too don't really want the full deal just something for the center. <-- thats what my leg feels like after a long road trip...
Old Jul 30, 2009 | 12:06 AM
rws.1's Avatar
rws.1
ceramic coated tunnel plate
Old Jul 30, 2009 | 07:38 AM
biglite351's Avatar
biglite351
I have never had the car up in the air, but I would guess this is not an easy thing to do.
I just figured that since I have all the hardware off the center and am waiting to get my HVAC unit back, I could just do an easy quick-fix thing.
I ran behind yesterday and did not get to Home Depot, but I hope to today.
Old Aug 2, 2009 | 09:25 PM
robsc501's Avatar
robsc501
Hi There:
Post the install pictures please.I know what the item looks like.
thanks.
robsc501
Old Aug 3, 2009 | 05:04 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I only used one layer of Frost King and the heat reduction was pretty significant I'd say;
Old Aug 3, 2009 | 08:27 AM
robsc501's Avatar
robsc501
Hi there tstar:
I was looking for the pictures of the solder heat shield install from the other poster.Thanks for posting your pictures.
Are you planning on going to Carlisle?I hope the weather is not so hot as last year.Pa. is a big place mind if I ask where you are located?
Have a great day.
robsc501
Old Aug 3, 2009 | 03:25 PM
tstar's Avatar
tstar
Yep probably Sunday... Sorry for posting the wrong pics for you!
I'm in DuBois...
Tim
Old Aug 4, 2009 | 12:40 PM
biglite351's Avatar
biglite351
I did want Tstar did, but I didn't take the seats and everything out.
Old Aug 4, 2009 | 05:23 PM
tstar's Avatar
tstar
I lined the whole car...
Tim
Old Aug 4, 2009 | 05:26 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
It will keep you cool--even in Florida.
Old Aug 4, 2009 | 05:27 PM
jodfit's Avatar
jodfit
St. Jude Donor '07
I did mine yesterday, it whipped my butt doing it in the heat but the results are well worth it.
To Center console heat shield?
