Is it normal that the console door only opens a very small amount? My C4 used to open fully while my new C5 barely opens enough to get my hand in there. I don't want to force it, especially if that is normal.
It's a two part hinge. You need to lift up and towards you on the second hinge. Open it a little bit, then spray some WD40 on the hinge. With it lubricated it will move freely. This happens all the time. It may seem like you are going to break it the first time, but it should open to full vertical.
I just learned something!
Thanks OP... good question.
Took me about a month and half...i kept looking at it saying that is the dumbest design. I was like what is stopping it...nothing. Pulled towards me some and it poped up and out.
Dam, thought I was the only one! Just lubed it with some silicone spray and it works fine. Damn thing still never latches down unless its locked though, Whats up with that?
Go ahead and pull up with a little more effort - it will come up to a 90 degree position.
