Sound deadning
Jul 30, 2009 | 07:27 PM
Sound deadning
who makes the best and cheapest sound deadning for my C5? I have new seats coming so that would be a good time to do it.. thanks John
Jul 30, 2009 | 07:45 PM
Do a search for Frost King. From what I have seen over time, it consistently gets high ratings and you can get it on the cheap at Home Depot or Lowes. Also search Mike Mercury for install instructions.
Good Luck.
Chris
Jul 30, 2009 | 08:33 PM
Try putting house fiberglass insulation in plastic garbage bags and stuffing in the rear 3 wells.
Cheap, easy, light and you won't believe the difference ! The wells pick up tire/road and exhaust noise and amplify it.
Jul 31, 2009 | 07:59 AM
This is a situation where BEST and CHEAPEST are at each end of one line.
You choose something along the line and as illustrated more toward BEST is less toward CHEAPEST and more toward CHEAPEST is less toward BEST.
There are other considerations and compromises such as weight, etc..
Jul 31, 2009 | 08:51 AM
St. Jude Donor '08
SecondSkinAudio.com
the Best products at a reasonable price. They're stuff is a big hit in the Audio section. They're acoustic foam makes a world of difference especially if you have loud exhaust.
Jul 31, 2009 | 08:53 AM
thanks
Thanks Guys I will explore your ideas.. Thanks John
Jul 31, 2009 | 09:22 AM
RAAMAT and Ensolite, reasonably priced and works wonders.
Aug 4, 2009 | 05:26 PM
Hi There:
The best & the cheapest do not go together most of the time.Dynamat is the best,but not the cheapest.E-bay has a better price takes 70sq. feet to do the whole car.
robsc501
Aug 4, 2009 | 05:35 PM
St. Jude Donor '07
Quote:
Originally Posted by
Oldvetter
Just curious, do you have a trunk partition?
Aug 4, 2009 | 06:00 PM
no its a coupe with 2 subs in the back..Thanks John
Aug 4, 2009 | 09:02 PM
PR1AWRet
Aug 5, 2009 | 08:15 AM
The seat removal/installation is so easy. If you can coordinate it great, but if not don't let that be the deciding factor.
Aug 5, 2009 | 09:35 AM
jodfit
Not originally, but I replaced the fiberglass with acoustical foam cone insulation. When I did this, I placed some insulation on the back of my fabric hatchback "cover".
The foam was like $45.
Here is my original thread, it is rather long:
http://forums.corvetteforum.com/c5-g...dproofing.html
Aug 5, 2009 | 10:07 AM
TheRadioFlyer
SecondSkinAudio.com
Very true. The OP did say "the cheapest" and Second Skin Audio isn't the cheapest but definitely worth its cost.
Aug 5, 2009 | 12:22 PM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I just bought my Pre-Cut kit from MADVETT
http://cca.madvettemotorsports.com/s...t_detail&p=105
The cost is really inexspensive and it is pre-cut, PATCHES did a nice write-up on it and was really pleased. mine is on the way
Thanks,Matt
