Thinking about getting these. Good or Bad Deal!!!!
Someone posted this in craigslist and I'm thinking about getting them. I have a stock 2002 coupe and I'm also going to eventually get wider wheels and tires so I thought the zo6 sways would do.
Is this a good deal or can I get a better deal? These are front and back sways for 150.00. used.
Also, since I'm upgrading the wheels to be wider is there anything else i should get besides the sways to improve handling????
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
If you are going wider wheels you don't want them to stick out, You might need new widebody kit.
You'll love the improvement Z06 sway bars give you...add a set of poly bushings to them with a set of Bilstien Sport shocks and you'll swear you're driving a different car!!!!
You can run up to a 12in wide wheels on the rear with the right offsets without them sticking out. I had the CCW classics big street package 18x12 rears with 335/35/18s without them sticking out and the fronts were 18x10s with 275s without them sticking out either. It is all about getting the correct offsets.
I am running 19x10/19x11 iforged right now with 305s on the back and 275s on the front with no problems with them sticking out.
