New Shifter is Sweet!
Old Aug 1, 2009 | 02:43 PM
Carcass's Avatar
Carcass
Default New Shifter is Sweet!
Installed an 09 C6z06 shifter today after work -took about 40 minutes,and it's great!
Knew the stock C5 shifter in my Vette seemed kinda "sloppy",but I didn't realize just how bad it was!
AND,it cured the "I'm not sure if I want to go quite all the way into first and reverse" problem that my tranny had!
Worth every penny.
modifying the C5 boot to work with the C6 **** was a piece of cake...
The GMPartshouse does it again,Thanks, Gene.
"I'll Be Back"
Old Aug 1, 2009 | 03:25 PM
tlc0706's Avatar
tlc0706
Ahhhhhhhhh...a happy post
Old Aug 1, 2009 | 04:58 PM
TakeAwayTheFear's Avatar
TakeAwayTheFear
im going to agree C6Z shifter FTW
Old Aug 1, 2009 | 06:22 PM
csexton's Avatar
csexton
Good to hear, enjoy
Chuck
Old Aug 1, 2009 | 06:38 PM
(Lucy)'s Avatar
(Lucy)
Account disabled by request Dec 2015
Awesome!!
Old Aug 1, 2009 | 06:46 PM
SCM_Crash's Avatar
SCM_Crash
What exactly did you have to modify on the boot? Is the shaft thicker?
Old Aug 1, 2009 | 07:28 PM
BAMvette's Avatar
BAMvette
St. Jude Donor '17
Made the same mod in our 'Vette about 3 weeks ago.
Glad I did....It's been VERY enjoyable....
On the boot, the C6 **** is thicker. To get it to fit I chose to split the last couple of seam threads, invert it and use a couple zip ties to secure it above AND below the **** bolt.
Others have done similarly, or chosen a different route. Mine seems fine, and looks OEM.
Search function will return lots of ideas for you. Look for "Patches" post......MOST informative!
OP may have a different method and will chime in as well, I'm sure.
Old Aug 1, 2009 | 07:55 PM
Carcass's Avatar
Carcass
SCM_Crash:
No,the shaft isn't any thicker,but the **** extends down the shaft apx. 3/4",and it's about 3/4" dia.,but to make it look right,you've got to bring the boot up to meet the leather on the ****,over the 3/4" plastic part of the ****.
Easy to do:
Remove the boot,and turn it inside out.
On the small end,the leather is folded back over itself and glued with some hella good GM glue.
But,the glue is no match for a pair of either needlenose or duckbill pliers -just grab it and start slowly pulling it loose,work your way around a little at a time,and try not to rip it(although you can get away with about a 3/8" rip,and it won't show when you're done)
Then,pull off all the pieces of glue on the end(when you get here,you'll know what I'm talking about)
WET the end of the boot down with some leather conditioner,and give it about 15 minutes to soak in...
then slowly force a 9/16" or 5/8" socket thru the hole--when it gets all the way through(end poking out) let it sit for a few minutes,while you install the shifter.
Before you install the **** on your freshly installed shifter, remove the 5/8" socket,slip the boot over the shaft(it's still inside out),and push it down as far as you can on the shaft,then put the **** on and give it a whack to make sure it's all the way down(no leather pinched in there). Hold the boot down while you put the screw/bolt in that holds the **** on.
THEN pull the boot up onto the plastic part of the **** till the end of the leather is flush with the plastic - then pull the boot down over the assembly,and snap the plastic ring in place.
You may need to put a zip lok around the end of the boot to keep it from sliding off the ****,but on mine,the screw/bolt stuck out enough to hold the boot in place just fine
Next,you step back,look at it ,and go "Oh Yeahhh"
Now,go drive the thing,and Smile.
Old Aug 2, 2009 | 06:19 AM
SCM_Crash's Avatar
SCM_Crash
Wow! Thanks for the write up... I think I'll have to buy a C6Z shifter now. The boot mod was the only thing worrying me enough to not buy anything. LOL
Old Aug 2, 2009 | 01:03 PM
Flex182's Avatar
Flex182
Old Aug 2, 2009 | 01:14 PM
vette.mix's Avatar
vette.mix
Is there a difference between the Z06 shifter compared to the standard C6, I’ve seem some of the C6 shifters come up in the parts section. How much is Gene charging?
Old Aug 2, 2009 | 01:42 PM
BAMvette's Avatar
BAMvette
St. Jude Donor '17
Here's the appropriate link to Gene's website....
http://www.gmpartshouseusa.com/partl...14638&items=10
Old Aug 6, 2009 | 12:34 AM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thank you for your business and your positive feedback. I certainly appreciate it. Here is the price this month for the special.
||--Genuine GM C6 2009 Z06 Shifter Kit--||
25823571 – C6 Z06 shifter
15851631 – C6 shift ****
11609670 - Bolt
Complete kit 195.96
For this kit on our website, use part number c6z06shifter under Chevrolet make.
This shifter kit works on all C5’s. The C5 boot will either need to be modified or you’ll have to purchase an aftermarket boot for a C5 that fits a C6 shifter.
Old Aug 6, 2009 | 12:55 AM
SCM_Crash's Avatar
SCM_Crash
Bolt? LOL What's the bolt for?
Old Aug 7, 2009 | 10:06 PM
BAMvette's Avatar
BAMvette
St. Jude Donor '17
I'd call it a screw....but that's just me.
It secures the **** to the shaft.....
Jeebus....that's close...:o
Old Aug 7, 2009 | 10:30 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
went B&M myself but have heard the same raves from buds!
Old Aug 7, 2009 | 11:14 PM
Gene Culley
Whether you're bolted or screwed it is the same thing isn't it?
Old Aug 8, 2009 | 07:55 AM
legman's Avatar
legman
Worth every penny.
"I'll Be Back"
Is the new one any shorter than the C5 unit you took out ??
Old Aug 8, 2009 | 02:08 PM
Congrats on the mod - always good to have a better shifter in the car.
To New Shifter is Sweet!
