From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Torque those wheels, and check them...
Put the new wheels on last week, torqued them down at 100ft-pd, well, decided to check them just now, man, I was surprised at how much both fronts had loosened , so I torqued them down again . 100ft-pds is correct, right?
Hi There:
I use the 100 ft.lbs. setting as the standard. I just ran across this info. while looking for other data. On page 3-98 of the 2001 s/manual it states to : Tighten the nuts in a criss/cross pattern to 190N-m(140 lb.ft.) I,am thinking it must be a typo error.
robsc501
From: Wylie TX --> Less is More, except under the hood !
I also torque all 4 wheels to 100lbs with the wheels "OFF THE GROUND"... not sitting on the ground. I pull the E-brake for the rears, and use my wheel locks for the fronts.
Mine don't. I took a wheel off yesterday and they weren't easy. Always torqued to 100 ft lbs.
Originally Posted by jrose7004
I always torque wheels at 100lbs.
Originally Posted by BAMvette
Factory Service Manual sez 100.
Toque
OK OK....I'll stop eating my wheaties and torque at 100 !!
Hi There:
robsc501
Must be a typo. My 2001 manual on disc states 190N-m(140 lb.ft.)
Hi There:
Thanks 87SAM for the acknowledgement
I appreciate it.
I think the same way you do typo error.
If this was an aircraft tech. manual we would be calling the engineers about this & have them issue a written supplement reflecting the change.
Have good weekend.
robsc501
