Optima Batteries
Old Aug 9, 2009 | 06:54 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Originally Posted by Bill K
No troubles with my Red Top, I have read that if you don't drive your car much you can have troubles, If your car sits all week one needs to put it on a battery tender of some type.
I have three operational red tops. Their ages are 8 years, 7 years, and 2 years. I got the two year old one while working at AutoZone last year, guy returned it though it was fine so I purchased as a used battery. I have had zero problems with any of them. If I'm going to park my car, I put a trickle charger on it for 1-2 nights per week.
One noteworthy thing -- you do NOT want to fast charge a red top. They don't like it, and it will put a hurting on them. If you have a dead one, trickle charge it over night and it should be fine.
Old Aug 10, 2009 | 11:20 AM
hotwheels57's Avatar
hotwheels57
A discharged OPTIMA can only take a very low amp charge. I've spoken to both DELTRAN CORPORATION (manufacturer of BATTERY TENDER) and OPTIMA representatives. The heat created by anything significantly over 1 amp will quickly shorten the life span of an OPTIMA battery. A slow and steady charge over time will usually bring them back to full capacity.
Float maintenance chargers like the BATTERY TENDER PLUS @ 1.25amp and the CTEK are perfect to maintain an OPTIMA at peak power during periods of hibernation.
My longest lasting red top OPTIMA went seven years with use of a BATTERY TENDER PLUS. I gave the charger to the guy who bought my car. He was still using the same battery two years later.
