Hood scoop install tips ???
Old Aug 8, 2009 | 02:13 PM
FRCVETTE99's Avatar
FRCVETTE99
Default Hood scoop install tips ???
Getting ready to install a hood scoop on my C5 . Anybody have any tips ? Have 3M epoxy to bond it on , and epoxy resin for fiberglass molding in . Need some tips and advice before I start !!!
Old Aug 8, 2009 | 05:10 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
Wash the hood with dawn dish soap and then use wax a grease remover.
Position the hood scoop on your hood and after your pleased with the location (centered, alignment etc.), mark the location by scribing a line.
Tape off right on and outside the scribe line.
Sand the immediate bonding area along the tape with 80 grit.
Sand the bottom edge of the hood scoop.
Bond the hood scoop to the hood with 3M bonding epoxy or Lord Fusor bonding epoxy.
After the bond has cured, use a da sander (or other means) to grind a 2" wide strip along the joint, 1" on each side of the joint. You want to remove enough material so you can build it back up with 3-4 layers of cloth and epoxy.
Layer in epoxy and cloth using the 2 part tubes and cloth from either 3M or Lord Fusor. I have used Lord Fusor 100EZ with good success.
After the top is solid and cured, you can remove the hood and cut out the underside and repeat the grind and bond procedure. After the layers have partially cured, you may want to put the hood back on the car to be sure you don't warp the hood any.
Sand and fill the bonding areas to the proper shape, prime, seal and paint.
If you will be finishing the underside of the hood for paint too, it may be easier to sand, fill, sand the underside of the scoop before you mount it to the hood.
Old Aug 8, 2009 | 05:23 PM
FRCVETTE99's Avatar
FRCVETTE99
Thanks ! Some good stuff there ! Will be taking it to the paint shop to have the "final" sanding and paint done .
Old Aug 8, 2009 | 05:52 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Post up some pics when finished.
Old Aug 8, 2009 | 06:08 PM
FRCVETTE99's Avatar
FRCVETTE99
Oh yea ! You bet I will !
Just sitting on the hood ! More to come later !!!
Old Aug 9, 2009 | 01:23 AM
74-Roadster
St. Jude Donor '06
Originally Posted by FRCVETTE99
Looks like you have quite a bit of trimming and/or filling to start with. Don't get tempted and try and force it into position. Take your time at the start. The position, height and rake will all determine how happy you are when it's all done.
And good luck.
Old Aug 9, 2009 | 12:52 PM
FRCVETTE99's Avatar
FRCVETTE99
And good luck.
I definitely have some work ahead of me ! If it turns out the way I hope , it will be well worth It !!!
To Hood scoop install tips ???
