Hydraulic Jack Selection?
Old Aug 8, 2009 | 03:55 PM
av8or's Avatar
av8or
Default Hydraulic Jack Selection?
The local Harbor Freight store has their Rapid-Pump aluminum racing jack on sale, $160. It's 3.25 inch height, 18 inch reach, 4000 lbs. I was about to buy it, but noticed that Wal Mart has a steel jack, 3.75 inch height, 18 inch reach, 6000 lbs for $95. No doubt both jacks are made in China. Any helpful input about either? I already know that the aluminum one is lighter.... but weight is really of no significance to me (other than lifting it from the shopping cart to the car).
Old Aug 8, 2009 | 04:14 PM
Oldvetter's Avatar
Oldvetter
I bought a steel jack called the "Black Jack" from WalMart. It is a low profile, Heavy Duty, jack. It has worked fine. It is very heavy, you must roll it anywhere. I think it is 3 ton and has a handle release.
Old Aug 8, 2009 | 04:18 PM
CHJ In Virginia's Avatar
CHJ In Virginia
The wally world jack has a 1/2" taller dimension on the jacking plate surface. That can be a problem especially if you have lowered the car. You won't be able to get the jack and jacking puck under the side frame rail. I use the Harbor Freight unit and it has been very reliable for 4 + years. Moving it in and out of the tool box on the trailer sometines several times a weekend, the light weight means a lot. Your use should determine the one you get.
Old Aug 8, 2009 | 04:21 PM
karateboi87's Avatar
karateboi87
I have that harbor freight one. I like it. It has dual pumps also. I also saw the walmart one (a while after I bought the HF one) and that looks like a good buy to..
Just so you know though, I think I paid like $130-140 for it. But HF tends to have different prices across the nation. I saw something online for $1 and when I went into the store it was $2.
Old Aug 8, 2009 | 05:23 PM
av8or's Avatar
av8or
Once the jack hits my garage floor, it could be years before I have to lift it again. The Black Jack is the one I saw today. Clearance is no problem for you? Do you use it with jacking pucks on the side rails?
Old Aug 8, 2009 | 08:29 PM
Hammer99's Avatar
Hammer99
I picked up an ARCAN XL 35R 3.5 ton steel floor jack at Costco for $99.00. Range: 3.5" to 21.5". Weight: 104 lbs.
Works great and doesn't feel heavy to use. Just keep it on the floor.
Old Aug 8, 2009 | 09:23 PM
widewheel's Avatar
widewheel
I bought a Harbor Freight racing jack a couple of years ago, but It seems like is was a lot less than $160. It is blue and silver annodized aluminum. The light weight and low profile make it really handy on the Vette.
Old Aug 8, 2009 | 10:15 PM
av8or's Avatar
av8or
Harbor Freight has a cheaper aluminum racing jack, approx 3.5 inch height, but it only has a 14 inch reach. Would work fine on the frame access points (puck locations), but would it work for the center lift points (forgot what they're called) to lift the entire front or rear of the car?
Old Aug 8, 2009 | 10:35 PM
tlc0706's Avatar
tlc0706
Bought a walmart jack several years ago (alum) for about $90.00, but think it only has a 14" lift. The lift has not been a problem as I drive up on ramps and use a 2x6 across the front member for extra support and heighth.
Old Aug 9, 2009 | 02:24 AM
Purple Corvette Jim's Avatar
Purple Corvette Jim
Default low profile jack
How low is the profile hight????
Old Aug 9, 2009 | 07:52 PM
widewheel's Avatar
widewheel
Here is the ad copy from the Harbor Freight website. They are listing it (U. S. General #91039) for $99.99 at the moment. I think they had them on sale when I bought mine for $69 or $79.
3000 Lb. Capacity Lightweight Aluminum Racing Jack
Aluminum racing jack lifts 3000 lbs. to a maximum height of 14-3/4"
Low-profile saddle with 3" minimum height, 360° rotating rubber pad
Made out of machined, high strength, aircraft aluminum billet material
4-5/8" wide, single front roller wheel
Two piece knurled aluminum handle prevents slipping
Handle overall length: 35-1/2''; Overall dimensions: 19-3/4" L x 9-3/8" W x 8" H
Weight: 24.2 lbs.
Old Aug 9, 2009 | 08:48 PM
karateboi87
Weight: 24.2 lbs.
I looked at that one too but I didn't like the 14-3/4" max height.. it's the same as a crappy $30 jack from autozone or whatever.
I think the 4000 lb one goes up to like 18" or something
Old Aug 9, 2009 | 09:15 PM
2KFRC5's Avatar
2KFRC5
http://www.harborfreight.com/cpi/cta...emnumber=47246
This one is 3.5" to 17.5"
Old Aug 9, 2009 | 09:37 PM
onevettenut's Avatar
onevettenut
I bought a Hein-Warner floor jack. It has a removable handle. The pad height is 3.25". It fits under my C5 and a 1" jack puck with room to spare. Jack is rated at 3000# and is all steel construction and USA made
Old Aug 9, 2009 | 10:36 PM
Oldvetter's Avatar
Oldvetter
I usually pull my front tires up on Rhino Ramps, then I use a small 2-ton jack with a puck to give me clearance on using the black jack with a treated 2X6 on the rear "rail". I jack it up and place the rear tires on another pair of Rhino Ramps. A poor man's lift, it keeps car level for checking fluids (trans and diff).
The Black Jack at WalMart jacks from 3.3 inches to 17.72 inches.
Old Aug 9, 2009 | 11:23 PM
rrichar2591's Avatar
rrichar2591
It's interesting you should mention both the Walmart Black Jack and the H F 2 ton jack. I've been looking for a good jack for the last couple of months. Have noted that they almost all are made in China. I ended up buying the Walmart Black Jack but once I got it home and unboxed, decided it was not what I wanted. Much too heavy and no pad on the lift arm. Took it back and got my money back and then bought the HF two ton jack. It it much lighter and has a lower profile.
By the way, if your worried about quality, you can purchase an extended warranty for around 35 dollars for two years. I will only be using mine two or three times a year so it fits my needs perfectly. Good luck.
Old Dec 9, 2009 | 01:58 AM
mrbooby's Avatar
mrbooby
1st Gear
Do you think it's a good idea to check Costco even if the jack isn't listed on their website? I'm in NJ btw.
To Hydraulic Jack Selection?
Old Dec 9, 2009 | 02:00 AM
TheDingo's Avatar
TheDingo
I bought this one not long ago.. it's a bad *** jack and the wide stage on it holds up the rear end without having to use a wooden board.
My car is lowered too, by the way, and it has no problems getting underneath the car. It lifts high, fast.
http://forums.corvetteforum.com/c5-g...-new-jack.html
Old Dec 9, 2009 | 10:09 AM
itzza427's Avatar
itzza427
H F has two sizes of their aluminum jack,,and I've had both sizes for a long time(est 8 years) and have used them from everything from sub compacts to my F-150 Super Crew!! One thing to consider,,the have them on sale OFTEN,,PLUS many car magazines are running adds for H F and they have 15 or 20% off on 1 item. Get a sale price THEN 20% off you can get a really good deal !!They work fine,,,and a LOT less weight to lug around!!!
Old Dec 9, 2009 | 10:39 AM
bumble-z's Avatar
bumble-z
HF has a steel low profile on sale next mo, in the mid $ 60 range. Thats the one I would get. Don't get the ex. warrenty, as with most jacks, including Sears (Esp. the alum. ones are all thow aways). Good luck.
