Got squeaky belts???
Old Aug 8, 2009 | 10:12 PM
drew47000000's Avatar
drew47000000
Default Got squeaky belts???
I DO! I'm not sure why or how this happened, but I do have one hypothesis. It's been raining ALOT over here *literally inches everyday*. My Vette's the daily driver so I'm guessing that water finally got somewhere it shouldn't have and now I have this really annoying squeak every morning on a cold start up, but this ONLY happens on the cold start up. It almost sounds like a blower would. Anywho, what's the best way to solve this problem. Thanks guys! As always, YOU ROCK!!
Old Aug 8, 2009 | 11:21 PM
Dominic Toretto's Avatar
Dominic Toretto
Sounds like what happened to me. Nothing to do with water though, if it is the same thing. Mine started squeaking not too long ago at about 60k+ miles. It was just do for the regular maintenance. Had the belts replaced along with the pulleys also. Mine did it on cold start too and would sound just fine as the engine would get up to normal operating temps. HTH
-Alex
Old Aug 8, 2009 | 11:22 PM
redrckt97's Avatar
redrckt97
start with the easy stuff - spray it with silicone - may have to do it a few times to quiet it down. I re-apply the silicone pretty much every time I drive in the rain.
Old Aug 8, 2009 | 11:36 PM
drew47000000
Where exactly should I spray it on and how much do I spray?
The car has 63,000 ish on it and I'm really hoping to avoid replacing belts and pulleys if I can help it.
Old Aug 9, 2009 | 12:00 AM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
When I had this problem I tried belt conditioner and it made it worse. I rubbed a bar of soap on the inside of the belt and the noise went away. Good luck.
Old Aug 9, 2009 | 12:36 AM
Dominic Toretto
You may not need to necessarily replace the pulleys, it was just recommended to me while I had the car being worked on. FWIW I have driven through some pretty big downpours and the water doesn't make the belts squeak. I also was able to drive my car quite some time like that, I think it upwards of 2 months if not more before I was able to afford to get the work done. Annoying yes but, it's still driveable without hurting anything, at least in my case.
-Alex
Old Aug 9, 2009 | 12:48 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
dont use belt spray.
main belt tensioner is the usual culprit. next is the AC tensioner. always replace the belt when changing tensioners.
Old Aug 9, 2009 | 03:58 AM
GHL4505's Avatar
GHL4505
Don't use the belt spray I tried that years ago. It didn't stop the chirpng and I received a lecture from my service tech on how that contaminates the belt.
Check the pulleys for debris, pieces of rubber from the belt etc. Then install Goodyear Gatorback belts. That cured the problem for me.
Old Aug 9, 2009 | 04:54 AM
Quickshift_C5's Avatar
Quickshift_C5
Had a belt chirping/squealing on my previous FRC. Swapped the old belt for a new one and it was good to go for the following 2 years I owned it. Just bought an 01 z06 and it's also chirping in a similar way. Just going to replace that belt as well and see if it cures it. I'm confident it will.
I refuse to rub soap, water, or spray the belt with anything.
Old Aug 9, 2009 | 10:10 AM
Blown427conv's Avatar
Blown427conv
Put a Gatorback belt on it. Thats the most common fix for the squeaky belt problems always on the tech side. It fixed mine. When you get your belt off to change it, turn and wiggle all of your pulleys to see how they feel to help determine if any are going bad. Probably just the belt though, and the Gatorback is well known for running quietly.
Old Aug 9, 2009 | 10:25 AM
rebelheart's Avatar
rebelheart
I agree,gatorback belt and cleaning your pulleys will take care of it!
Old Aug 9, 2009 | 11:27 AM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
I just had to swap my AC tensioner at a touch over 60k.... washed down the engine bay and the squeek started... must have gotten some kind of grit in the bearings. Easy enough fix tho...
Old Aug 9, 2009 | 01:37 PM
KeyoRacing's Avatar
KeyoRacing
I was in the same boat, tried everything... was going to change all the same things you are looking at then I went and for a Goodyear Gatorback belt for it ....FIXED! I think the belt was like $20 or something.
Give that a shot.
Old Aug 11, 2009 | 08:13 PM
drew47000000
Sweet.... I Love you guys!!! (but not in that weird kinda way)
Old Aug 13, 2009 | 09:10 AM
RON NARDONE's Avatar
RON NARDONE
How much will i pay for the a.c. Belt and tensioner repair mine is squeaking at start up too,however it stops after the engine gets warm....
Old Aug 13, 2009 | 09:31 AM
bucwheat's Avatar
bucwheat
Hey Andrew,I will be down there the second week in Sept.Maybe we can meet up at Aunt Catfish for dinner one day,let you know closer to the date. Family has a beach house on Daytona and we come down about 4 times a year.
Old Aug 13, 2009 | 12:35 PM
wcsinx's Avatar
wcsinx
Same thing happens to my car after I have to drive through the torrential FL downpours we have this time of year ... squeak squeak until it warms up. Looking down into the engine bay, you'll notice that crank pulley isn't even a foot off the ground and there's nothing protecting it. I think what's happening is when I have to chug through the deep *** puddles, road water is getting slung up on the belt and depositing road oil and debris which lowers the friction coefficient of the belt just enough to make it squeak until it warms up.
Now what I have done which works for me, but I'm sure I'll get criticized for is I take a rag and spray Prestone Belt Dressing in a little spot of the rag, then with engine idling I press that wet spot firmly on the inner surface of the belt (try to get it down in the grooves). The squeak disappears almost instantly everytime. However I would NOT condone using WD-40, silicone, or soap. Those are lubricants which will just make the problem worse while masking the sound. Proper belt dressing is actually a very mild adhesive and water repellant. I know this product gets poo-pooed by most everyone, but it works for me.
And replace your belts for peace of mind you lazy bastage. It seriously takes like 15 minutes tops.
Old Aug 13, 2009 | 12:42 PM
wcsinx's Avatar
wcsinx
I don't think it's the water itself. It's the combination of water and all the oil and road dirt it carries once it hits the asphalt.
You have to understand central FL rain. When it rains here, it chits and gits. We'll get an inch dumped on us in < 1 hour easily and routinely which leads to a lot of deep puddling.
To Got squeaky belts???
