odd sound after lights retract?
Old Aug 10, 2009 | 10:45 AM
329vet's Avatar
329vet
Cruising
Default odd sound after lights retract?
All, New to me, 2000 C5 has a whinning sound for about 10 seconds after the lights are retracted. It seems like a minor problem to me. I am told it is probably a vacuum or relay problem. Any thoughts?
Thanks, this is my first vet and is currently under warrenty for the next 30 days through Carmax. I plan to make them repair it, but I sure would like to be more knowledgable on this issue.
Ray
Old Aug 10, 2009 | 10:52 AM
MagRedConv's Avatar
MagRedConv
The gear is gone. Check out the Ultimate DIY sticky in the Tech section for the headlamp gear replacement step by step.
Old Aug 10, 2009 | 11:00 AM
329vet's Avatar
329vet
Cruising
Thanks, I will do so. I heard about these gears before, but the relay/vacuum idea/issue was unfamiliar to me. I check it out and reply when solved. Thanks again.
Old Aug 10, 2009 | 11:08 AM
But since you have a warranty, let them do the repair - even if it involves just replacing the entire headlight motor.
To odd sound after lights retract?
