C6 wheels...?
Old Aug 10, 2009 | 03:54 PM
CharlieB1979's Avatar
CharlieB1979
Default C6 wheels...?
I'm dead positive that this has been addressed more than multiple times...but alas, I need assistance!
I am interested in purchasing the below tire types:
2 Rear 19x10" Offset is 65mm. Bolt pattern is 5x120.65. Hub Size is 70.3
2 Front 18x8.5" Offset is 46mm. Bolt pattern is 5x120.65. Hub size is 70.3
Would they fit on a C5 Coupe (non z06)?
Old Aug 10, 2009 | 04:36 PM
my6thvette's Avatar
my6thvette
They fit on mine.
Old Aug 10, 2009 | 04:39 PM
19torch99's Avatar
19torch99
Yes they fit. I've heard it's 50/50 that you'll need to run a spacer so they don't rub on the inner wheel well due to the incorrect offset. I decided to run a 1" adapter to make them sit more flush with the outer wheel well. Here are some pictures:
Old Aug 10, 2009 | 04:56 PM
my6thvette's Avatar
my6thvette
This is what the C6 rear wheels look like without a spacer.
Old Aug 10, 2009 | 05:38 PM
BLAQK's Avatar
BLAQK
no spacers, rubbing so bad i need a new tire. prolly won't run into that unless your car is slammed tho. I'm going to space them out a little. They do look good on our cars though.
Old Aug 10, 2009 | 08:57 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Are the C6 wheels shown GM wheels or are they C6 reproduction wheels made to fit C5's?
Old Aug 10, 2009 | 09:53 PM
my6thvette's Avatar
my6thvette
Mine are OEM C6 wheels with original factory Goodyear GS-2 tires.
Old Aug 10, 2009 | 10:40 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
1/4 inch spacer here...allows plenty of stud length so you can tighten wheel nuts without fear of failure. I had rubbing on the inside before adding spacers.
Old Aug 10, 2009 | 10:51 PM
Mike99FRC's Avatar
Mike99FRC
I have stock C6 wheels on my car with no spacers with no problems so far.
Old Aug 11, 2009 | 09:37 AM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
this is a C6 wheel
Old Aug 11, 2009 | 01:48 PM
my6thvette's Avatar
my6thvette
Woops, that was the wrong picture. That one is the C5 wheel. Here is the C6 wheel, for comparison.
Old Aug 11, 2009 | 02:08 PM
John G Pircsuk's Avatar
John G Pircsuk
I also run C6 OEM's with a 1/4 spacer in the rear. No rubbing ever. Longer studs are not needed; you will get full thread engegement.
Old Aug 11, 2009 | 05:37 PM
stingraymyway
So C6 wheels will work with spacers.
DAYMN!!!
I want a set of the new 9-spoke alloy Callaway wheels so bad.....
To C6 wheels...?
