[Z06] Does your Z leak coolant?
Old Aug 11, 2009 | 09:35 AM
Morfias4twenty's Avatar
Morfias4twenty
Default Does your Z leak coolant?
I have noticed that every once in a while I have a coolant spot under my car.. This does not happen all the time. I guess it happens when I've been out on a long ride or when I have get on it really really hard.. Now the spot is not big at all its kinda small but it still bugs me. Could it be a radiator issue? A res issue? WTF?? lol Has any one ever had this happen?? Its a 01 Z.
My guages don't read as if its heating up the temp runs right around 198-205 or so when im on the rd. but I opend up the hood right after a run cuz I heard the sound of water boiling and sure enough it was coming from the reservoir.
any input?
Old Aug 11, 2009 | 09:39 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Sounds like your system is not air tight and it has a leak somewhere.
Maybe a bad seal on the resevoir tank cap or lose clamps, cracked tank, etc ...
No leaks and no boiling over.
any input?
Old Aug 11, 2009 | 09:49 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
It's probably just water from the air conditioning condenser.
Do you have to continually add coolant?
Old Aug 11, 2009 | 10:11 AM
Morfias4twenty
I have checked preaty much everything.. ...Wha wha whaaaaa..
The fluid does not seem to drop.. and i know for a fact its not water.. cuz it has the slippery coolant feel.. plus it the same red/orange color.. (DexCool) lol
Old Aug 11, 2009 | 04:01 PM
winters97gt's Avatar
winters97gt
mine had a leak in the system. Added more coolant until the ratio of coolant to water was high, and it sealed the leak on its own. 5k later, no issues.
Old Aug 11, 2009 | 04:19 PM
Morfias4twenty
Im gonna try that..
thanks bro
Old Aug 11, 2009 | 05:30 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Im gonna try that..
thanks bro
Do not do that, To much anti-freeze to water ratio will cause your car to overheat.
Water is actually a better cooling agent than anti-freeze. The anti-freeze is there to stop the system from freezing and damaging the block and other components.
Old Aug 11, 2009 | 05:38 PM
winters97gt
yes, I agree, I should have mentioned that I was running more water than coolant. My car doesn't run hot, I would guess that I am around 60/40 now.
Old Aug 11, 2009 | 06:35 PM
RonnieM's Avatar
RonnieM
I had a bad hose clamp on the hose that connects to the bottom of the throttle body. You can't see the clamp, you have to feel for it. It didn't leak all the time and the only way I found it was to pressurize the system. Turns out the clamp was bad from the factory in 04
Old Aug 11, 2009 | 08:37 PM
2K3Z06's Avatar
2K3Z06
From: KADS- If it has wings or an engine, I can break it. Dallas TX
Look at the bottom of your water pump. Does the drip hit the top of your leaf spring?
Let the car sit overnight, check the water level in the overflow tank, should be up to the cold water mark.
Old Aug 12, 2009 | 09:21 AM
Morfias4twenty
Ok guys .. Im thinking it might be my water pump.. I poped the hood let the car run for about 10 min.. ( no drip) but... get this the Small tensioner belt was wet. and I touched the water pump pully and sure enough i touched dang fluid..
Has anyone had ther water pump go out?? could this be it?
Old Aug 12, 2009 | 05:58 PM
2K3Z06's Avatar
2K3Z06
Sounds like the seal on the water pump is leaking. Try using a small mirror and flashlight for a better look. The belt shouldn't be wet.
Best of luck on the repairs.
Old Aug 12, 2009 | 06:36 PM
Stevo92z28's Avatar
Stevo92z28
No idea if LS motors have the weap hole. But it's common on older cars with the weap hole slowly leaking antifreeze. Normally a sign its about to go.
Old Aug 12, 2009 | 08:16 PM
lbarnard's Avatar
lbarnard
I was at Road Atlanta and a ZO6 had an antifreeze leak that turned out to be a feeze plug that was the problem. Anitfreeze leaks are not common. If you can get the car on a rack after getting it up to operating temps you should be able to see where it is coming from.
Old Aug 13, 2009 | 10:54 AM
Morfias4twenty
Thanks fellas... I'll try to get into it this weekend..
I ran the car last night to one of out local meets, stayed on it a bit.. and when i got home.. nothing.. no leak no drip.. nothing.. So i guess this only happens when it wants to.. its frustrating..
Old Aug 13, 2009 | 04:41 PM
4SFED Z's Avatar
4SFED Z
I know your problem. Coolant is coming out the weep hole from your water pump. I can almost promise thats it. Was a PITA for me to figure out. I went to advance auto and bought one with a warrranty for a little over $100. Changed it out in an hour and a half...took time not to get coolant all over me
Old Aug 15, 2009 | 07:40 AM
David426's Avatar
David426
Its the water pump.. I went through the exact same thing about 1 year ago and it drove me nuts.. There is an infarred green dye that you can add to your radiator.. Put this stuff in and in a couple of days you will be able to get under the car and pinpoint or verify that it is indeed the waterpump leaking when it wants to.
To Does your Z leak coolant?
Old Aug 15, 2009 | 02:35 PM
TEXHAWK0's Avatar
TEXHAWK0
One thing for sure...once the water pump seal starts to leak, it will not get better. Just a matter of time before you have to change it.
The seal should not leak enough to drip at all. GM will say if there are signs that it seeps but does not drip that is normal.
Old Aug 16, 2009 | 10:00 AM
bobby777's Avatar
bobby777
any input?
That coolant leak was an option--Glad I didnt order it
Old Aug 17, 2009 | 09:10 AM
Morfias4twenty
dang thing did not leak all week end. I orderd the dye should be in tues. I will go from there. i'll keep u fellas posted.
