Fuel sending unit
Old Aug 11, 2009 | 10:28 AM
Keppah's Avatar
Keppah
Default Fuel sending unit
Looking to buy 2 new fuel sending units for a 1997 Corvette.Any ideas where I can buy them and does anybody know cost of units?
Old Aug 11, 2009 | 11:08 AM
02MillenniumVette's Avatar
02MillenniumVette
Are you sure you need to replace them? If its because they are corroded then they can be cleaned up by using Techron or Seafoam. Its going to be really expensive to have them replaced.
Anyways you can contact Gene Culley at www.gmpartshouse.com and Im sure he can get them for you.
Old Aug 11, 2009 | 11:17 AM
Humy's Avatar
Humy
Old Aug 11, 2009 | 11:19 AM
bucwheat's Avatar
bucwheat
Two cans of Seafoam in two tanks and the gauge will come right back,the swap is very expensive.
Old Aug 11, 2009 | 11:38 AM
Keppah's Avatar
Keppah
Default fuel sending unit
Thanks for reply.Tried Techron still having problem not all the time seems after driving about 45 minutes it will stop working set codes and it will work most of the time.
Old Aug 11, 2009 | 02:14 PM
.Anyways you can contact Gene Culley at www.gmpartshouse.com and Im sure he can get them for you.
And his prices will be the lowest you can get from what I have found.
To Fuel sending unit
