Have you tried putting the old one back in?
You could run a tap through it, but you'd have shavings in the cylinder. If you try it, put some vaseline on the tap to catch as many of the shavings as possible. Go slow and straight. Work the tap in a little, then work it out. Don't just drive the tap all the way in. Taking time with this will save you! Every time you back the tap out, wipe the tap off and put more vaseline on it. Do this until you can seat the spark plug in place. You don't have to load the tap with excessive vaseline. If it works, try to clear out the vaseline from the threads. Make sure you put anti-seize on the spark plug threads if you don't know.
Hope this helps.
Helicoil BUT, depending on which plug, you may have to pull the head anyway. You could try a thread chaser to clean them up again but if you really galled them, a helicoil is really your only option short of a new head.
Go to the parts store and pick up a thread chaser/cleaner. Cover with vaseline or a thick grease and see if you can't salvage the threads before taking more drastic measures.
I just want to emphasize THREAD CHASER/CLEANER!!! MANY try to substitute a regular tap to chase threads,,and especially in aluminum THAT could be a BIG mistake!!! Quite a difference between them!!
I guess I'm one of the many, but as of yet, NO issues. That includes an LS1 spark plug hole a friend messed up on his GTO. But yeah, I'll agree with the chaser/cleaner. I guess I've just been used to a tap for to long.
And, after "cleaning/chasing", be sure to just snug up the new plug, don't over torque!
Jeez....Mariah Carey is pathetic these days....she's on some show singing while I type this...no...badly lip sinking...not singing...very badly.....her new "hit" called "why are you so obsessed with ME".....Girl....you ain't all that...at all....what happened to the great singer we knew? SAD...so sad....her lips weren't even matching the lyrics....sorry, not to take this off topic but she's just obsessed with herself these days....
Hope this helps.
