Installing New HoodLiner
Old Aug 13, 2009 | 11:15 AM
97c5vette's Avatar
97c5vette
Default Installing New HoodLiner
How easy/hard is it to install a new hoodliner?
Is it as simple as removing the old plugs and the old hoodliner and then using the same plugs install the new one or am I to anticipate some unexpected install surprises?
Old Aug 13, 2009 | 11:19 AM
Bills03Coupe's Avatar
Bills03Coupe
Default New hoodliner
It's very easy. Just remove the plugs and it's off! To install, it might be easier to have a second person help you hold it in place, while you install the plugs.
Old Aug 13, 2009 | 11:27 AM
jrose7004's Avatar
jrose7004
Couldn't have said it any better.
Old Aug 13, 2009 | 11:37 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
You can reuse the old retainer plugs if careful. If not its not to expense to buy new ones.
Old Aug 13, 2009 | 12:07 PM
orangecrush08's Avatar
orangecrush08
I just replaced mine with an embroidered 50th logo, I reused all but one of the original retainers which I found at Auto Zone quickly.
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You might consider using a body trim plug puller to minimize the damage to the plugs if you plan to reuse them. Some folks have used a two tine BBQ fork to pull the plugs with success. If you need new ones, they're pretty cheap.
Old Aug 13, 2009 | 12:31 PM
97c5vette's Avatar
97c5vette
Thanks all
I'll put up photos once it's installed
Old Aug 13, 2009 | 06:03 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
Its that simple.
Old Aug 13, 2009 | 07:36 PM
dobewillie's Avatar
dobewillie
good luck with install
Old Aug 13, 2009 | 08:17 PM
c5blkvetteguy's Avatar
c5blkvetteguy
There was a diy thread were someone used chrome pluming plugs (like the one in your sink if you dont have the spray nozzle) and put over the factory black plugs. It was a very nice look for not much money.
Old Aug 14, 2009 | 02:54 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
FWIW All the ones above my exhaust were brittle and broke...
Old Aug 14, 2009 | 12:01 PM
bucwheat's Avatar
bucwheat
The BBQ fork works well.
Old Aug 14, 2009 | 09:37 PM
Dads C5's Avatar
Dads C5
What if you wanted to paint your hoodliner instead of purchasing a new one. Is it worth it? What kind of paint?
Old Aug 14, 2009 | 10:06 PM
rrichar2591's Avatar
rrichar2591
http://forums.corvetteforum.com/c5-t...th-pics-2.html
DeeGee posted this how to (see post #36). It's the best one I've seen and I plan on using it to do mine. Good luck and many thanks to Dave for taking the time do do such a great write up.
Old Aug 15, 2009 | 12:01 AM
Razorback58's Avatar
Razorback58
My hood liner has started to delaminate on one of the corners at the top. Has anyone had this happen, and if so were you able to fix it? I've thought about spraying it with 3M glue to see if I could get it to stick back together.
Old Aug 15, 2009 | 08:28 PM
Dads C5's Avatar
Dads C5
Many thanks....Dave
Old Aug 15, 2009 | 08:41 PM
It's as easy as you describe. Just be careful when you pull the plastic fasteners loose so you don't break off the little tabs on the end. But if you do break the tabs, replacement fasteners are pretty cheap.
Old Aug 18, 2009 | 06:08 PM
Dads C5's Avatar
Dads C5
I purchased some fasteners from my local chevy dealer for $1.49. I guess that's a good price, maybe wholesale. I've known the parts man for 20 plus yrs.
Old Aug 18, 2009 | 08:46 PM
doug doo wop's Avatar
doug doo wop
go to carmotorsport.com and get a good liner with embroidered logo. You can either buy the liner already done or they will mail the cover and you can glue it on yourself(alot cheaper).
To Installing New HoodLiner
