Follow the wire from the light and you'll find the connection by the bottom of the hood. If not, maybe it's as simple as a dead bulb.
This connection is right on the front firewall and 'Right' where water and dirt can fall on it. I had a hell of a time with my underhood light till I cleaned both sides of the connector and then filled it with Permatex, dielectric tune up grease, #67VR. I also installed the famous "Hood Seal" which really works great at keeping water and dirt from getting into the connector in the first place. I did it two years ago and haven't had any trouble with the underhood light since.
Sorry your 'jacked up' brother.
I bet you have high blood pressure too!
Chill out and relax man
Uhmm I really don't think that is what he meant by JACKED UP!
You go to know Vega$ most mellow dude you'll know -
If you have your OWNERS/Manual book in the glovebox all the bulbs are listed in the back section so you will not need to panic when you need to know which bulb your Vette takes
Originally Posted by madmatt9471
..........If you have your OWNERS/Manual book in the glovebox all the bulbs are listed in the back section so you will not need to panic when you need to know which bulb your Vette takes
If the lamp was out in you house wouldn't a guy at least check the bulb before he called the electrician out.
Come on guys we are all here to help each other but can you at least put out the effort to check the obvious first?
i KNOW my bulb is out. I pulled it at a car show so it didn't kill the battery and forgot to put it back it never found it's way back in the car. Now i know the bulb number and will be replacing it soon
