Flush auto trans fluid???
Old Aug 14, 2009 | 05:32 PM
olefam's Avatar
olefam
Default Flush auto trans fluid???
My 2004 with auto trans is a virtually stock car. It has a Volant intake and BB cat back exhaust. Odometer shows 32000. Car is not raced nor driven very hard. My question is whether the trans fluid should be flushed? When I call GM dealers, all 3 said yes to a flush, but it wasn't necessary to replace filter. One mechanic explained that GM recommends a procedure where a chemicle is added to the old fluid. Then the car is driven to warm it up. Finally the fluid is flushed, and new fluid added. The chemicle supposedly ensures more thorough cleaning of deposits and build ups. And I was assured that this procedure even cleans the filter itself, so no need to replace.
I've never heard of anything like this before. Can anyone comment who has either had this done, or who went a different route.
TIA.
Glen
Old Aug 14, 2009 | 05:49 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
When I modded my engine, while it was on the rack, I let them change tranny, and gears, put RP in all, engine, tranny, and gears. I guess it won't hurt to change it for your peace of mind. Not sure about the added chemical from GM. Other guys will probably chime in with good info.
Old Aug 14, 2009 | 05:58 PM
karateboi87's Avatar
karateboi87
This is interesting, experts come on in!
If the tech is right, it sounds like a good idea.
Old Aug 14, 2009 | 06:29 PM
billla's Avatar
billla
St. Jude Donor '14
I would never - ever - "flush" a transmission, or anything else for that matter. Change the fluid, call it good.
Old Aug 14, 2009 | 06:55 PM
karateboi87
Except, a few quarts will be remained in the system.
I originally assumed that flushing isn't necessary also until I read about it.
Old Aug 14, 2009 | 09:45 PM
Carlos Arredondo's Avatar
Carlos Arredondo
I had my 04 auto trans fluid changed abput a month ago at 47,000 miles. The dealer told me the same thing but I wasn't to comfortable with the way that sounded. Foud a corvette shop to do the trans , diff and radiator fluid exchange and they did do the filter. The is no drain plug on the auto trans sothe pan has to come off to change the fliud. The fliter is a $30 part. While he's was in there they agreed that chancing it was some peace of mind for cheap. The macjanic also explained that there is a maginet in the bottom of the pan put in at the factory that catches any metal in the system. Mine was working as it should. A few bits of metal were stuck to it.
Old Aug 14, 2009 | 11:49 PM
jrprich's Avatar
jrprich
I am no expert in transmissions........
There is a power flush where the fluid and/or solvent is "flushed" backwards with pressure, sometimes high pressure. Many say this can dislodge crud that may end up getting stuck in new places where it may foul up your tranny. I think this is what one finds at most Jiffy Lube type places.
This is different from a "fluid" exchange where the new fluid is pumped through the entire transmission in the regular direction that trans fluid flows and the TC at regular trans pressures to pump out all the old fluid and replace it with fresh fluid........some also call this a "flush".
Old Aug 15, 2009 | 12:59 AM
billla's Avatar
billla
St. Jude Donor '14
Is in the GM Service Manual? No.
Is the stuff you're reading written by the people that sell this service? Yes.
Totally your call of course, just one guy's opinion
To Flush auto trans fluid???
