Help identify vibration/noise
Old Aug 16, 2009 | 09:12 PM
pechorin75's Avatar
pechorin75
7th Gear
Default Help identify vibration/noise
I have an '04 automatic. So far it's been great--no problems--but there's one annoying little thing that's been bugging me since I bought the car. Most of the time, when I pull away from a stop, there's a very brief low-frequency "vibration" noise that seems to come from somewhere in the rear-end of the car. Seems to be related to the speed of the engine just off idle. My guess is that it's something in the exhaust system--a shield or something vibrating against something else as the engine comes off idle--but I have no way to verify that.
Anybody else notice the same thing, or have other ideas? It's not a big deal, but it sounds kinda cheesy, so I'd like to fix it if I can.
Thanks!
Old Aug 16, 2009 | 10:55 PM
craigwirth's Avatar
craigwirth
I had a similar noise coming from mine for months. Turned out to be the a/c tensioner. $187 fix at Corvettes of Dallas. Hope yours is as cheap and easy. Good luck
Old Aug 16, 2009 | 10:59 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
If it is coming from the exhaust, you might have a catalytic converter with the guts a little loose.
Old Aug 16, 2009 | 11:01 PM
Stevo92z28's Avatar
Stevo92z28
I bet it's the 2 springs that hold the exhaust up near the transmission. Very common rattle.
Old Aug 17, 2009 | 06:16 AM
Atok's Avatar
Atok
Is there a common fix for that? I've got that rattle on my Z06.
Old Aug 17, 2009 | 07:36 AM
craigwirth's Avatar
craigwirth
Any decent performance shop will check the the springs, as well as the cats, if you tell them you have an exhaust rattle. LG checked that first thing on mine. Unfortunately, that wasn't my issue, but they replaced half of the H pipe at no cost anyway. Good people
Keep in mind that many rattles or vibrations originating in other areas will travel the length of the exhaust
Old Aug 17, 2009 | 08:07 AM
Stevo92z28's Avatar
Stevo92z28
http://forums.corvetteforum.com/c5-g...st-rattle.html
Old Aug 17, 2009 | 10:26 AM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
I think I had that same problem when my LG Streets were installed, the whole package, cats/x-pipe, seems the long tubes were just a hair too close to the tunnel plate, when I took off from a stop, it moved just enough to vibrate. Brought it back and the guys corrected the problem. Hope this helps.
To Help identify vibration/noise
