C5 AC Problems
Old Aug 20, 2009 | 03:35 PM
Jim O'Reilly's Avatar
Jim O'Reilly
1st Gear
Default C5 AC Problems
is it a common problem to have a malfuntion with the temperature sensor that controls the heating and AC? With my 1999 C5 frequently the ext temp reads in the 30 degree range when its 80 degrees outside and instead of AC all it will put out is heat. It usually corrects itself after a while.
