The MadVette C5 Pre-cut Insulation kit comes with everything you need to insulate and provide sound deadening in your Corvette, including Pre-cut pieces for your doors.
Other kits on the market provide a similar product, but do not provide pre-cut pieces for your doors, which allow road noise to be present in your front cabin. Our kit gives you everything you need to COMPLETELY insulate your C5 Corvette.
Our kit is a non-fiberglass, non-asphalt based product which weighs in at 3.5 lbs, for those who are weight conscious, it rejects 97% of the radiant heat, and has a manufacturer's rating of 19db of sound and road noise reduction!!!
It is only 3/16" thick, so as not to interfere with proper mounting of your panels and seats, and all holes are pre-cut & clearly labeled for your convenience.
It is our #1 goal to provide you ease of install, while making a HUGE improvement in your overall enjoyment of your Corvette!!!
Each kit is hand cut to our specifications, and guaranteed to make a dramatic difference in your C5!!!
Each kit comes with the following pieces:
Driver & Passenger front floorboard pieces, with holes cut for seat bolts and pedals.
Driver & Passenger side tunnel pieces, cut around your e-brake.
Full center console pieces, with holes for the center console bolts.
Driver & Passenger side Door Panel pieces.
Full Cargo area floor pieces.
Full Side rear wheel well pieces.
Full back wall and corner pieces.
Full Center Well pre-cut pieces.
Extra pieces for the rear speaker areas.
Extra pieces for odds and ends coverage that you may need.
Say goodbye to over-heated center consoles, and noisy front cabins!! Our C5 kit is the perfect addition to your C5, and is recommended for every Corvette owner as the #1 modification for their Corvette!!!
Your Corvette will be cooler in the summer, alot less noisy, and you will regain use of your center console once again.
Alot of research and development has gone into this kit, and we are proud to say that our kit is made to our demanding specs, in house, and cut off of our own templates.
Pictures of the kit installed in a C5 vert are below.
How does this kit compare to the Dynamat as far as the sound deading.
Thanks,
Russell
Dynamat is a better sound deadener, but where my kit, which consists of 80 sq. ft. of material, weighs only 3.5 lbs. total, 80 sq. ft. of Dynamat would weigh about an extra 30-40 lbs.
My kit also accomplishes the rejection of heat that occurs in the C5 and C6's, where as Dynamat does not.
Hope that helps.
After removing the carpet throughout the vehicle, it appears that we would need to apply some type of adhesive to the carpet to secure it. Is this an accurate assumption?
No, actually, none of the carpet is glued in at all; it just sits in the car, and is secured by things like the center console, rear side speaker panels, etc.
