[Z06] Does your Z have this noise
Old Aug 22, 2009 | 06:01 PM
TBH94's Avatar
TBH94
Default Does your Z have this noise
This may be in my head but I swear I hear a slight knock noise in the engine. It is random. It does seem to follow engine motion but it is intermit. I can hear it in the car also. Maybe in the clutch flywheel area. The trans is in the back so I don't think it is that. Does not change with clutch in or out. The car has loud B&B exhaust so it can be hard to hear.
It sounds like poss. a lifter. It does not seem to be bottom end. I know the engine is aluminum and they can be louder than iron.
How do other guys Z's sound. Absolutly quiet? Or are there noises that come and go.
It seems these engines are pretty strong and can take some abuse. Before I bought it I read about them and it seemed like all the bugs were worked out by the '03 model year. As far as piston slap and things like that.
I just got it a week ago and will be changing all the fluids soon. Oil, clutch, brake, trans and diff.
She is a 2003 Z with 41k miles. No leaks under car and clean oil and coolant.
What do you guys think?
Thanks in advance for any help
Old Aug 22, 2009 | 07:22 PM
bluez06ny's Avatar
bluez06ny
It could be a lifter, or cam. When you change the oil, take the oil filter and cut it open with a chisel and snips. Cut out the paper and look for metal from something like your cam flaking away.....I always do this every oil change to see what's going on.
Old Aug 22, 2009 | 07:41 PM
TBH94's Avatar
TBH94
Great idea. I will do that.
Is this a common issue? Cams and lifter failure?
Are there some common engine failures on Z's?
I guess as long as it doesn't get louder or mess with performance I should just drive the car and have fun. Provided I do not find metal in the filter.
Thanks again. Anyone else feel free to chime in. I am new to c5's and am learning as much as I can. Been reading as many posts as I can to learn more.
Old Aug 22, 2009 | 07:55 PM
02Z06clark's Avatar
02Z06clark
I have an 02 Z when I first start it up it makes a little noise but when all warmed up it's fine, could be piston slap ?
Old Aug 23, 2009 | 09:50 AM
got2hav1's Avatar
got2hav1
2019 C6 of Year Finalist (performance mods)
Default Noise
Its hard to say without hearing it in person. But both of the LS6 engines I have had would tick in the manner you are describing. I think it is normal for the engine. Both my cars have been low mileage and not abused . Good Luck.
Old Aug 23, 2009 | 01:15 PM
krazyKanuck's Avatar
krazyKanuck
I vote for piston slap
Old Aug 23, 2009 | 01:20 PM
Z06_BluByU's Avatar
Z06_BluByU
these motors were supposedly to be designed to be quiter than the Gen II engines... but I think in the case of the Z06 the sacrificed some noise issues for the performance.. heck 405hp out of 346cid is dam good!!! they also omitted some sound insulation from the car for weight reasons.. so you hear more in these cars than normal corvettes...
Old Aug 23, 2009 | 08:21 PM
TBH94's Avatar
TBH94
Is piston slap par for the course in these cars?
It seems like a lot of people talk about piston slap as if it happens to every vette.
Thanks for the input everyone.
Old Aug 24, 2009 | 08:11 PM
z06dailydriver's Avatar
z06dailydriver
If it's a ticking noise, it's the fuel injectors. Mine has been making this noise since new, almost 8 years ago. No issue
Other noises are alternator whine, torque tube whine and a ringing noise out of the exhaust
To Does your Z have this noise
