Got back from a ride yesterday, went to roll my windows up and nothing. All the power controls on the drivers side door are dead. I could get the passenger side window up with the control on that side. I checked the fuse it was fine. I need help????
Open drivers side door and wiggle accordian that wires run through, There is a plug in connection that has a exposed wire from factory , just get some liquid tape and cover bare wire.
Rubber will pop right out of door jamb on body side, you will find a plug in there , mine had a bare wire exposed that you can put liquid electrical tape on and your good to go!
Thanks for the help I will get it fixed as soon as I have some time
Mine did the same thing about a month ago. Fix it soon. After a week or so it started giving me "Service Traction Control and ABS" warning messages. The electrical systems on these cars are wacky. Fix the other side too - both of mine were in bad shape.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Hmmmm.....I may need to check mine. I have no problems with either door working but I do have the same warning messages. I will pull the accordions and check the wiring and the grounds that are supposed to be there. Thanks for the tip.
There unfortunately are various electrical issues that can cause it. Try that, then check the grounds, and then look to see if you ever had a leaking battery.
Did you try checking for any codes? You should get a code saying that the control module for the door couldn't be found.. It may be a good idea to check your grounds too.
