Manual transmission Linkage
Old Aug 23, 2009 | 08:53 AM
James Kinne's Avatar
James Kinne
Default C5 Manual transmission Linkage
I have a 2000 FRC and I can't make a gear selection. Lost linkage hookup something either broke or came disconnected. Any likely problem common to this condition? Appreciate any ideas! Thanks
Old Aug 23, 2009 | 09:04 AM
Jet-Jock's Avatar
Jet-Jock
That bolt may have broken that secures the shaft.
Review this post to understand the connections and linkages.
http://forums.corvetteforum.com/c5-g...tallation.html
Old Aug 23, 2009 | 11:52 AM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Check the attached PDF to see the shifter box to shaft detail. It it's loose or broken you lost the connection from the shifter to the tranny.
File Type: pdf
To Manual transmission Linkage
