[Z06] My First Oil Change
Old Aug 23, 2009 | 11:53 AM
RrobeyD's Avatar
RrobeyD
Default My First Oil Change
It's time for me to do my first oil change on my 04 Z06 and I'm not taking it to Jiffy Lube! The previous owner had used Mobil 1 which if I'm not mistaken is Chevy's recommendation......what weight, what brand oil filter?? Any advise before I get under my car for the first time?? Just hoping to head off any surprises before they pop up.
Old Aug 23, 2009 | 12:09 PM
Paul 75 L82's Avatar
Paul 75 L82
I'm going to do my first this week some time. I plan to use Mobil 1 5w30, but I don't know which filter.
JimbeauZ06's Avatar
JimbeauZ06
You'll get plenty of opinions on oil. Mobil 1, Royal Purple, Red Line, Valvoline are all good high quality products. Any premium full-synthetic will work just fine. I use Mobil 1 oil and filter.
Old Aug 23, 2009 | 12:28 PM
bartsky's Avatar
bartsky
I just changed mine with Mobil 1 5w-30, and Mobil 1 M1-107 I believe is the filter. Be sure and use have jack stands and blocks. I also tilted the rear up to get all the oil out.
Old Aug 23, 2009 | 12:54 PM
arkus's Avatar
arkus
Filters----->mobil 1
Amsoil
Redline
K&n
oil--------->mobil 1 10-30
Redline^^^^^
Amsoil^^^^^^
Old Aug 23, 2009 | 04:18 PM
TEXHAWK0's Avatar
TEXHAWK0
WIX filters, and I just switched to Valvoline Synpower.
As long at it meets the Corvette spec, you should not have a problem. There are oils that are now equal to, and better than, Mobil 1.
Old Aug 23, 2009 | 04:32 PM
ls1impulse's Avatar
ls1impulse
I use Mobil1, although have considered switching to AMSOIL; and I always use NAPA GOLD filters (these are WIX filters)
Old Aug 23, 2009 | 05:19 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Let me add to the thread too. I always use Mobil 1 and Wix filters. Once in a while I have thrown in a Mobil filter because I am too lazy to drive the distance it takes to get the Wix filter.
Old Aug 23, 2009 | 07:11 PM
dbaker's Avatar
dbaker
I use Penn Plat 5-30 and Pure One filters on all my rods.PL14006 fits my 02Z.
\db2
Carolina
Old Aug 23, 2009 | 07:22 PM
Stevo92z28's Avatar
Stevo92z28
Well i run M1 10w40 because i track my car, but for street duty i would run 5w30. I run a standard ac delco filter PF46. Any premium synthetic is fine for the car.
When changing your oil, open the drain plug then lower the car so it's level with the ground so that the rest of the oil can escape the pan or you can raise the back to accomplish this. If you don't you will leave 1/2-1 quart of old oil in the pan.
I think specs say 6.5 quarts but go ahead and throw 7 in there. Won't hurt and you will probably burn that half a quart by your next oil change.
Old Aug 23, 2009 | 07:24 PM
arkus's Avatar
arkus
What is a wix filter ?
Old Aug 23, 2009 | 08:30 PM
hattitude's Avatar
hattitude
Wix is the name of the manufacturer. They make the NAPA filters.
I too use a NAPA Gold (Wix) #51042 and I just switched to Valvoline SynPower synthetic 5W30 oil. It now has the GM4718 rating.
Good luck
Old Aug 23, 2009 | 08:42 PM
BobbyC3's Avatar
BobbyC3
From: Common courtesy and common sense are not common.
St. Jude Donor '09-'10-'11-'12-'13
Mobil One(and filter), but K&N and Wix are good as well.
Also I found this thread VERY helpful to jack the car properly......
http://forums.corvetteforum.com/c5-g...-question.html
Good luck
Old Aug 25, 2009 | 09:58 PM
acrace's Avatar
acrace
And it also takes a lot of time for all the oil to drain out. I like to raise the car, remove the drain plug, and then eat breakfast or lunch.
Another reason to not go to a quick change place.
Old Aug 26, 2009 | 09:44 AM
Warped Sol's Avatar
Warped Sol
One reason TO go to a quick change place is if you don't have a proper way of disposing of the old oil.
I'm not a tree hugger, but people who toss the used stuff in jugs in the trash or pour it on street cracks to kill weeds drive me nutz. That's even with me being a part of the Evil Oil Empire.
Actually, I've found a oil change place that caters to high end cars. The pit monkeys are very knowledgeable, and the service guys on top know their Vettes, Lambos, Porsches, and Ferraris. I don't mind paying the extra to have the oil disposed of properly, and the employees know their cars.
Old Aug 26, 2009 | 10:51 AM
James92's Avatar
James92
Is there a problem with Fram oil filters that I don't know about? Nobody mentioned they were using them.
Old Aug 26, 2009 | 05:20 PM
CraZee ZO6's Avatar
CraZee ZO6
\db2
Carolina
HELL YA! me too
we know whats good
To My First Oil Change
Old Aug 26, 2009 | 07:04 PM
Mello03's Avatar
Mello03
I have seen Fram filters cut open compared to many others and their quality is noticeably inferior. I saw this about 3 or so years ago and have never used another. Just do a quick search on it and I am sure you will change your mind.
Old Aug 26, 2009 | 09:26 PM
ptindall's Avatar
ptindall
They use cardboard where quality filters use steel. WIX is a good filter.
Old Aug 26, 2009 | 09:28 PM
ptindall's Avatar
ptindall
THINK WITH YOUR DIPSTICK, JIMMY!!
