the M6
Old Aug 24, 2009 | 12:05 AM
jimmymc's Avatar
jimmymc
Default the M6
having trouble with the tranny. When I go to shift to 6th , it does not want to go in and some times grinds. Can this be the fluid?
any help is very welcomed
Old Aug 24, 2009 | 09:41 AM
jimmymc's Avatar
jimmymc
ttt
Old Aug 24, 2009 | 11:04 AM
jimmymc's Avatar
jimmymc
the car has 80,xxx miles and is a 2000 vert
Old Aug 24, 2009 | 12:58 PM
jimmymc's Avatar
jimmymc
ttt
Old Aug 24, 2009 | 03:40 PM
VetteR1's Avatar
VetteR1
I had a similar situation when I was shopping for a C5 over the weekend at CARMAX, everytime I put it in 1st gear it would grind I even told the salesperson to drive it and it is transmission problem. They would get it fixed this week it looks like a clutch pad replacement. It is 2002 6spd with 37,500 miles. I'm glad I have not purchased it yet.
Old Aug 24, 2009 | 03:59 PM
Black04Z06's Avatar
Black04Z06
Sounds like a worn clutch or you need to bleed the clutch. Have you checked your fluids?
Old Aug 24, 2009 | 04:56 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Try changing the fluid but more than likely a worn synchro, time to get hooked by Rodneys team over at RPM.
Old Aug 24, 2009 | 05:27 PM
Oldvetter's Avatar
Oldvetter
If you have a 1997-2000 C5 you have paper blocker rings. If someone put in Mobil 1 ATF, this could cause this. I experienced this with my 1998 after 50,000 miles. Your 6th gear synchros don't go bad (who speed shifts into 6th?!).
I changed fluid to Amsoil ATD and it stopped grinding immediately and is fine after 20,000 more miles.
Old Aug 24, 2009 | 06:16 PM
Old Rotor Head's Avatar
Old Rotor Head
Two things I'd look at Jimmy before you tear into it.
1) clutch fluid, look at the side of the clutch master if the fluid is grey or black it's time to change. Or open the cap and check it and the level. I use DOT3 even though I have a full C6Z clutch package.
2) Shifter alignment, you can read post on the Forum, it doesn't take much to have it grind or bind in certain gears.
Old Aug 24, 2009 | 07:00 PM
jimmymc's Avatar
jimmymc
thanks for your replys, I changed the fluid to day with mobil 1 full syntic and the old stuff looked milky,so I'm thinking ordinal will drive some and report back
Old Aug 24, 2009 | 07:10 PM
Eric the Ricer's Avatar
Eric the Ricer
From: Beyonce > Taylor Swift - Welcome to the good life!
St. Jude Donor '07
Sounds like you need to hit the gym
Old Aug 24, 2009 | 07:34 PM
Black04Z06's Avatar
Black04Z06
Good point, because it only happens in one gear.
Old Aug 25, 2009 | 12:35 AM
itzza427's Avatar
itzza427
DANGER,,WARNING,,,get that Mobile 1 out of there ASAP!!!!! It will KILL your syncro blocker rings!!!!! Amsoil or Royal Purple if you want synthetic but NOT Mobile 1!!! 97 through 2000 have the "paper faced" blocker rings that will be degraded by Mobile 1!! Fluid change is a good idea and a place to start,,you just used the wrong stuff!!
Old Aug 25, 2009 | 08:52 AM
jimmymc's Avatar
jimmymc
I think your rite, because even tho it feels smother it is still having trouble in 6th guess i wasted 40 bucks ,even tho auto zone said that this was the replacement for dex3
Old Aug 25, 2009 | 11:36 AM
jimmymc's Avatar
jimmymc
can anyone tell me who has royal purple in st.louis mo.
Old Aug 25, 2009 | 02:31 PM
TooMch's Avatar
TooMch
I thought I saw some in O'Reilly's the other day. Try calling them.
Old Aug 25, 2009 | 06:20 PM
robsc501's Avatar
robsc501
H There:
with ajg1915
Worn out 6th gear synchro.If the car had low miles I would change out the fluid & that would probably cure the problem.
robsc501
To the M6
Old Aug 25, 2009 | 10:17 PM
jimmymc's Avatar
jimmymc
Originally Posted by robsc501
H There:
with ajg1915
robsc501
if? 82000 is LOW?
Old Aug 26, 2009 | 03:00 AM
randy814u's Avatar
randy814u
Seems to me, napa carries it.
Old Aug 27, 2009 | 02:41 PM
jimmymc's Avatar
jimmymc
I think 6th gear is going out, all other gears feel good but slight grind when going in 6th
thanks for all your help
