Down shifting the 6 speed
Old Aug 24, 2009 | 01:33 PM
realvc's Avatar
realvc
Default Down shifting the 6 speed
I have always down shifted 4 speeds to slow for curves and to stop. This is the first 6 speed I've driven/owned and read some where that the brakes were to be used to slow down not the transmission. I have been down shifting to slow and for curves with out useing the brakes that much. Is this harmful to the transmission?
Old Aug 24, 2009 | 01:38 PM
Navyvette04's Avatar
Navyvette04
I down shift all the time from the higher gears (6,5,4). For some reason, I never down shift to 1st gear. I do not think I have done any harm to my transmission.
Old Aug 24, 2009 | 01:39 PM
dougbfresh's Avatar
dougbfresh
Brakes are cheaper than clutches/transmissions-use the brakes for stopping, that's what they are for.
Old Aug 24, 2009 | 02:29 PM
But I did on occasion downshift to slow the car down.
Old Aug 24, 2009 | 02:35 PM
ChromeC5's Avatar
ChromeC5
If you match the revs of the engine to the speed of the transmission, it does not wear on the clutch....however, this is easier said than done sometimes.
I've have down-shifted the tranny from the higher gears as well without any adverse affects. Once in a blue moon if I have to down shift into first, I'll double clutch to make it a little easier on the synchro's.
Old Aug 24, 2009 | 02:41 PM
Roostertail's Avatar
Roostertail
St. Jude Donor '06
True enough, but if you're going to worry about one thing or another being expensive to replace might as well just park it.
If you're driving on the street probably better to use the brakes, but if you're out for some spirited driving in the twisties go ahead and down shift. Drive it like it was intended to be driven You gotta pay to play...
Nick
Old Aug 24, 2009 | 02:44 PM
BAMvette's Avatar
BAMvette
St. Jude Donor '17
I downshift at will.....
If I need to replace a clutch down the road, so be it.
Old Aug 24, 2009 | 02:48 PM
spladam74's Avatar
spladam74
102k on my '99 and I have downshifted to first for nearly every light, curve, and exit ramp. 10 years and no problems.
Old Aug 24, 2009 | 03:07 PM
TooMch's Avatar
TooMch
Heck, there are times I even downshift the A4 for curves. Keeps the car in a better rev range. That was the one thing I hated about having the A4 instead of the A6 was the paddle shifters. I know their execution is not that great in a Vette, but if I'm stuck with an automatic, I'd like the option. It would make it more palatable. I also know the A4 has some advantages over the A6. It's never a clear cut choice is it?
Old Aug 24, 2009 | 03:20 PM
MrMojoRisin921's Avatar
MrMojoRisin921
I like to drive in a balanced manner, double clutch when downshifting and also use my brakes and I never ride my clutch when stopped on a hill.
Old Aug 24, 2009 | 03:48 PM
KenShores's Avatar
KenShores
Go ahead and shift as required. it more fun too!
Old Aug 24, 2009 | 03:53 PM
karateboi87's Avatar
karateboi87
What advantages does the A4 have over A6?
A6 has more gears, selectable gear, higher torque capacity.
I'm jealous of the A6.
Old Aug 24, 2009 | 04:19 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Default There is a proper gear for everything.
My Zo6 is a perfect driving machine, one that deserves to be in the proper gear. When I'm behind the wheel, I'm not there to loaf around.
I rev match the transmission whenever I downshift for whatever reason.
Not many people know how to do it properly.
Old Aug 24, 2009 | 04:24 PM
Thalomos's Avatar
Thalomos
If you're worried about cost, just use your brakes. They're cheaper and you may as well put the wear and tear on them.
If you enjoy downshifting - as long as you know how to match revs - enjoy it. That's what the car is meant for. I have done this on all of my cars with no problem. But I usually only shift down to 3rd at the lowest gear when casually getting around town.
Old Aug 24, 2009 | 04:40 PM
TEXHAWK0's Avatar
TEXHAWK0
A 6 speed is just a 4 speed with 2 overdrives, so drive it the way you would any manual transmission.
I generally downshift when driving in the mountains to keep from over heating the brakes, but around town, I just use the brakes to slow the car down.
Old Aug 24, 2009 | 04:55 PM
tail_lights's Avatar
tail_lights
I rarely downshift unless I am getting ready to punch it!
Old Aug 24, 2009 | 05:01 PM
Oldvetter's Avatar
Oldvetter
The video that came with my car said that the Corvette's brakes are so good that there is no need to downshift to slow down the car.
I also say brakes are cheaper than clutches.
The only good reason to downshift is going down a long, steep hill. This is also a good reason to downshift in an automatic car. Continued use of the brakes in this case could cause them to fade.
To Down shifting the 6 speed
Old Aug 24, 2009 | 06:22 PM
Old Rotor Head's Avatar
Old Rotor Head
I rev match my down shifts and changed my stock clutch at 100k miles just because. It still had plenty of life left.
Old Aug 24, 2009 | 06:26 PM
Jet-Jock's Avatar
Jet-Jock
I down shift the 6-5-4 range for example coming off an interstate as I want to have engine control and not be free coasting. However, during in town driving I don't down shift that often mostly just use the brakes as stipulated in the owner's vid.
Old Aug 24, 2009 | 06:37 PM
ALLEGRO's Avatar
ALLEGRO
I downshift, but usually just for the fun and sound of it. Most times, I just use the brakes.......paid for them too you know.
