Sagging Roof Help
Old Aug 24, 2009 | 07:25 PM
muelledc's Avatar
muelledc
Default Sagging Roof Help
Can anyone recommend a good permanent fix to the roof "caving in?"
Thanks for any ideas!
Old Aug 24, 2009 | 07:42 PM
dobewillie's Avatar
dobewillie
cant help you hope someone chimes in good luck
Old Aug 24, 2009 | 10:02 PM
muelledc's Avatar
muelledc
Default Thanks
Thanks, me too. I got the weather stripping taken care of, but have no idea what to do with the roof panel.
Old Aug 24, 2009 | 10:07 PM
Aerovette's Avatar
Aerovette
No promises, but if it were me I would mask off anything you do NOT want adhesive on and spray 3M trim adhesive on it and gently put it back in place. Let it get tacky for a short while before you put it in place or you may have fingertip impressions if it is just plain wet with glue. I do NOT have experience with this exact problem, but fixed a friend's typical 80's GM headliner this way.
Old Aug 24, 2009 | 11:14 PM
jrose7004's Avatar
jrose7004
I've never seen that problem before.
Old Aug 25, 2009 | 12:38 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Your bad window mouldings let water into the headliner on your hardtop.
Only thing to do is go buy a new one.
Old Aug 25, 2009 | 12:50 AM
LoneStarFRC's Avatar
LoneStarFRC
Mine is doing the same thing except it is not in the advanced stage that the OP's is. I've got new weatherstripping already and a new headliner on the way and I am going to remove, clean, and reseal the areas involved. The new weatherstripping already has a butyl type sealant pre-applied in key locations and is covered by a peel off tape. I will primarily use butyl tape (doesn't dry out) and I may augment that with some black silicone only if necessary. Any and all screws used need to have the threads sealed as well. New ones come with it already.
Old Aug 27, 2009 | 12:32 AM
muelledc's Avatar
muelledc
Default Thanks
Thanks for the replies, I'll pick up a new headliner.
Old Aug 27, 2009 | 10:07 AM
LoneStarFRC
No chance. Discontinued by GM.
Old Aug 29, 2009 | 07:01 PM
muelledc's Avatar
muelledc
Default Discontinued
GM parts seems to have it under part number 10434742.
Any other ideas to pick one up if the above is incorrect?
Old Aug 29, 2009 | 08:12 PM
LoneStarFRC
Good luck on finding a new one.
I would remove the old one and probably use a suitable brush-on type adhesive on the fiber type material, brushing it in between the "layers" you have now, then set a weighted item on it to compress it back to it's original thickness and dry. I'm thinking something like an Elmer's glue, or similar, etc. Elmer's starts out white and dries clear.That will at least "restore" and preserve the headliner as best as possible.
The real task is to stop water from getting to the headliner in the first place. Remove the trim moldings (2 per side) and the weatherstrip retainers (also 2 per side) and the weatherstrip, clean everything and reseal everywhere there was sealant before. Probably be a good idea to use a little extra sealant where you can, especially between the trim molding and the body, and then in between the trim molding and the weatherstrip retainers too. Prior to re-installing the weatherstrip itself, lay a continous bead of sealant down the middle of the weatherstrip retainer(s) and then insert the weatherstrip and get it tucked back into the channel that holds it.
HTH
To Sagging Roof Help
