Tire Repair Kit
I'm thinking of ditching my GY Runcraps and getting some GY GSD3's. Gonna need a repair kit.
I have had to change two flats in the field. The first was in the driveway, and I was seriously in trouble with just a pump and a patch kit. I could not get the nail out, and there was no way I was going to patch the tire, and would have been stranded.
Bottom Line, for a Tire Repair Kit, think of the absolute worst situation you can think of and prepare for it.
My kit consists of a air pump with a light on it, headlamp, a small jack, so I can get the tire off(Think of trying to patch a tire that has a nail on the inside front), Lug nut socket, 1/2 breaker bar, Needle nose pliers, round nose pliers, screwdriver, , a bottle of water, rubber glove(this is a dirty job), a blanket to lay on, a cheap $3 poncho in case it is raining, and a GOOD tire patch kit, not a cheap one under $10. These are tough tires, so you need a decent T-Handle plug tool.
Sounds like a lot, but it all fits in a stuff sack in the left side cubby, with the exception of the jack, which is my center cubby. It is only 12-14 inches long and about 3 inches high with it's own handle. I think it came from a Taurus. and cost me $8 from the local Pick-N-Pull junkyard.
My second flat was in my work parking lot, and I had it fixed in about 15 minutes.
I carry a plug kit, sealant, compressor, AAA card and a cell phone. Once you drive this car with non run flats you'll never go back.
Here is the section that says it can damage the tire sensors:
The ContiComfortKit combines a powerful, high-volume, 12-volt air compressor, integral pressure gauge and a latex liquid tire sealant packaged in a compact, lightweight unit that's easy to store in the vehicle. (Kit is 9.5"W x 7"H x 3.75"D.) This product's sealant may interfere with the tire pressure monitoring sensors on vehicles with direct TPMS, possibly leading to error prompts and incorrect pressure readings. Use of this product on direct TPMS vehicles could also result in damage to the tire pressure sensor inside the wheel.
I carry slime brand sealant instead because they state on their website that there sealant will not damage tire pressure sensors.
I think they lied because that's about when I bought the kit and I thought when I bought it that they said it would not hurt the sensors, but as you can see they now say it will damage the sensors.
Would have left me stranded, so I would look for something a touch better.
For those expecting AAA, or other roadside assistance keep in mind their flat repair service means they put on a spare. AAA will NOT come out and patch a tire. Make sure you let them know you have to be towed on a flatbed. When I had my flat in the parking lot it was at least a two+ hour wait, since the flatbed was already in use and they told me there was someone in front of me.
I will most likely go back to RF's on my C5, running Nitto 555's now. I put RF Michelin Pilots on my C6 and I really like them, and I have some RF security. The technology has come a long ways since the original RF.
Has anybody successfully repaired a tire themselves with one of these kits? Did you use the sealant? Did you have to remove the shrader valve?
I've used mine for years , at least 10 , without a mishap !
I've plugged my tires , friends and co-workers tires and never had an inkling of a problem.
Maybe you just got a defective one or I got a good one
& marinehacker202
Ya definitely not my idea of a good time
