Dynatech Header & Cat problem
Old Aug 26, 2009 | 09:35 PM
Bobd207s's Avatar
Bobd207s
From: Cancer Sucks - please donate to Corvettes Conquer Cancer
Cruise-In X Veteran
St. Jude Donor '08-'09
Default Dynatech Header & Cat problem
Hi
Earlier this summer my buddy bought a 2000 Coupe that included Dynatech Header Kit with the Powerfow Cats - Corvette C5 system (#115-736300S) . Recently a code started showing up on the DIC indicating a problem with the Cats. Does anyone have experience with this - I apologize I don't know what the code is a but a Corvette only shop told my buddy the problem is with the CATS
TIA
Bob
Old Aug 26, 2009 | 11:04 PM
tlc0706's Avatar
tlc0706
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history Stolen from Bill Curlee...the guru's will need codes....
Old Aug 27, 2009 | 01:48 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Originally Posted by Bobd207s
Hi
TIA
Bob
I can toss out an early guess and say it's prolly the rear o2 sensors. LT headers usually need the rear sensors tuned out/disabled.
Like I said it's just a guess until you can post up a code to verify.
Old Aug 27, 2009 | 01:59 PM
Bobd207s's Avatar
Bobd207s
Cruise-In X Veteran
Thanks guys
I am waiting for my buddy to get me the codes and I'll post them
bob
Old Aug 27, 2009 | 02:41 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
He needs a tune...
Peace
Chip
__________________
..................Click for
Old Aug 27, 2009 | 09:17 PM
7LitreC5's Avatar
7LitreC5
If it is the cat efficiency code it will be normal with those cats. Mine did that as well. I just tuned it out with EFI Live.
Old Aug 28, 2009 | 12:26 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
P0430 ?
Old Aug 28, 2009 | 01:28 AM
swollix's Avatar
swollix
I will swap you my stock headers & x-pipe at no cost. That should clear up the code.
Old Aug 28, 2009 | 01:33 AM
shadeshift's Avatar
shadeshift
Old Aug 28, 2009 | 12:10 PM
tlc0706's Avatar
tlc0706
Old Aug 28, 2009 | 12:12 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
You have a stock x-pipe?
Old Aug 28, 2009 | 02:44 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
99% of the time that is what it is. Cat efficieny code. The hi-flow cats don't burn off enough emissions, because they are "hi-flow"
Get a tune, and code will go away.
Old Aug 28, 2009 | 07:35 PM
dobewillie's Avatar
dobewillie
good info post
To Dynatech Header & Cat problem
