Help removing interior panel
Old Aug 28, 2009 | 08:44 AM
97c5vette's Avatar
97c5vette
Default Help removing interior panel
I'm trying to remove the plastic interior panel where the shoulder/seatbelt is attached into.
I'm kinda hesitant to disconnect the shoulder belt from the sidewall but can't figure any other way to remove the panel.
Can someone please help and tell me what I should do to remove this interior panel?
Thanks for any guidance
Bruce
Old Aug 28, 2009 | 09:38 AM
Vette-kid's Avatar
Vette-kid
Bruce, you are right. The seatbelt will have to come off. Its not really too difficult, ou will need a torx socket and breaker bar or impact gun for that (its on there pretty tight!). Once you have that out of the way, the panel should come off pretty easy. They are just held on with those little plastic interior clips. It helps to have an interior trim tool. Its basically a small prybar that you can fit behind the panel to help release the fastener. Go slow and careful not to damage the clips. Good luck.
Old Aug 28, 2009 | 09:42 AM
97c5vette's Avatar
97c5vette
Thanks Sean
I actually just bought that interior clip pry bar from my local mac driver when I removed my hoodliner
ok, I'm gonna give it a try. I'm replacing the panels with CF panels
I'll post pictures when I'm done
Old Aug 28, 2009 | 09:43 AM
Vette-kid's Avatar
Vette-kid
Originally Posted by 97c5vette
Thanks Sean
To Help removing interior panel
